Thought I would share the work I picked up this week as it is a little out of the ordinary for me. I have done this kind of work but it usually only comes up maybe a half a dozen times a year. The pics are of pieces that are related to the aviation work I do. They are a mix of thick steel and aluminum parts and call for 1/4" fillets and/or V-groove fills.
The first pic is of an assembly after final welding. It is clamped to a small surface plate while it is cooling. It was clamped this way for the initial welding, and then clamped again to cool after heating the backside (in order to minimize warpage). The second pic is a weld close-up of that same part. The third pic is of two separate assemblies that hold, and support, a larger axle assembly for an engine transmission. They have the first pass completed and are cooling in preparation for the final pass.
The last two pics are of the aluminum assemblies. In the first one, the part on the left is set up to show what it will look like after welding. The pieces to the right are the same thing only a mirror image. The last pic is an assembly that gets 4 equally spaced two inch fillets on the top and bottom. All this is being done to print spec. using my 300DX and my Precision Tig 275. Thanks for looking
Results 1 to 10 of 13
Thread: Big Tig welding
02-06-2006, 11:48 PM #1
Big Tig welding
Dynasty 350DX
Dynasty 200DX TigRunner
MM 350P
MM Passport Plus
Spectrum 375 Extreme
08' Trailblazer 302
02-07-2006, 06:11 AM #2
Kevin,
Great work as usual, I sure am lusting after those clamps
Regards, George
02-07-2006, 08:04 AM #3
Great job, always a please to see your work.
Laurence
TO MUCH BLUE TO LIST
02-07-2006, 11:51 AM #4
- Nov 2005
- 25
dude r u a bmxer ? i see the S & M sticker on the welding helmet
02-07-2006, 05:58 PM #5
very nice
02-07-2006, 11:37 PM #6
Ok, a few more pics. The first is of the steel assemblies after the final pass. Again, 1/4" fillets are all that were called for here. The second is a close-up of the large circular assembly. There are 6 equally spaced fillets around the top and bottom, this is one of the top fillets. The next pic is a close-up of the welds on one of the aluminum block assemblies from the previous picture #4. Thanks for looking and for all the kind words.
Dynasty 350DX
MM 350P
MM Passport Plus
08' Trailblazer 302
03-01-2007, 02:19 AM #7
- Jan 2007
- 105
I wish i could weld as good as you!
.. dam i'm jelous
.. i got the same question ,, do you Bmx ? i also see the S&M sticker.
Jorgensen MFG.
argonweld_bjorn@hotmail.com
www.ehhitch.com
03-01-2007, 06:25 AM #8
I could help with refreshments in the background.If you take to machining like you weld there will be no work for the rest of us.
Nice as always ,& keep the project pics coming.
03-01-2007, 07:52 AM #9
- Nov 2006
- Hampton, Va.
- 386
Beautiful welds as usual. Could you please tell us where you got thoseclamps.
Wheelchair
03-01-2007, 11:21 AM #10
- Jan 2007
- 105
i dont know where KB got em but i know you can get em at Air Liquide... they are like 80$$ each!! Ausome clamps tho
Jorgensen MFG.
www.ehhitch.com
