Results 11 to 20 of 23
Thread: Dynasty 200 DX problem
05-11-2007, 08:24 AM #11
- May 2007
- 539
05-11-2007, 10:01 AM #12
- Apr 2007
- 106
If you don't already have, you can get an assortment of tungsten (lanthanated and ceriated), collets, collet bodies and cups from HTP America in a handy kit box for reasonable price ($55 + shipping).
I ordered their gas lens kit, collets and a few lanthanted tungsten of each size -- they are very helpful and ship same day.
1-800-USA-Weld
No affiliation -- just hope this is helpful.
05-11-2007, 10:17 AM #13
- Sep 2005
- CT.
- 332
All I use right now are Zirconiated(Sp) tungstens. They are nice with my Dyn 300 machine and a gas lens.
T.J.Miller Dynasty 300DX
HTP MIG 240
HTP 380 Plasma
Bridgeport Milling Machine
South Bend Lathe
Etc. Etc....
tjsperformance.com
05-11-2007, 10:44 AM #14
Wow, lots of good tips. Time to go out to the shop and try them out.
Thanks everyone!
JD
05-11-2007, 12:17 PM #15
I will most likely be over there summer after this one, I want to do some touring in Germany anyway. If you are still hanging aroung here then I will get your address and visit. I mostly am on the Hobart "weld Talk" forum at http://www.hobartwelders.com but visit here and Miller "Motorsport" often.
Regards, George
05-11-2007, 01:14 PM #16
Something no one has mentioned yet is post-flow. If you have inadequate post-flow and/or you pull your torch away from the weldment too soon you will have tungsten frosting. It is something that is more prevalent with inverters in general but is not limited to them and will cause the exact problem that the initial poster experienced.
One good practice to get into is to lightly scratch the tungsten to your work before you strike an arc. Your start should be immediate when you do that.
If you are using pure or zirconiated with a Dynasty you are not realizing the full potential of your machine. Inverters are designed to run with a pointed tungsten and both pure and zirc will want to ball almost immediately. If you are going to use them, you might as well set your machine to 60 hz and run it like a regular transformer based unit.
IME, lanthanated and ceriated work best on my 300DX and 350DX. Thoriated also works well but I have gotten away from that because of health reasons and the performance isn't necessarily better.Dynasty 350DX
Dynasty 200DX TigRunner
MM 350P
MM Passport Plus
Spectrum 375 Extreme
08' Trailblazer 302
05-11-2007, 01:21 PM #17
05-11-2007, 01:28 PM #18
05-11-2007, 03:54 PM #19
- Apr 2007
- 106
05-11-2007, 04:31 PM #20
Dynasty 350DX
MM 350P
MM Passport Plus
08' Trailblazer 302
