Results 1 to 10 of 10
    Apr 2007
    347
    Default Paint Recommendations
    With all the welding going here, someone has to have figured out paint by now and I need some help with selecting the right paint for my latest project.
    Iíve just about completed my gate entrance. Itís basically an oilfield pipe rail fence. Iíve got the prep work down Ė Iíll sandblast it with my 350lb Schmidt run by my 175cfm Ingersoll-Rand air compressor. But selecting paint has always given me fits.
    For my last couple of trailer projects, Iíve purchased ďNasonĒ brand single stage enamel paint. I believe itís made by Dupont and uses your typical automotive hardner and reducer. It runs me $125 a gallon (including the hardner and some reducer), but is an excellent paint that stands up to UV rays and is comparative to automotive paint.
    For indoor projects, Iíll use whatever cheap enamel paint I can find. Rustoleum, Anchor, or if Iím painting it CAT yellow, Iíll get the paint from the local CAT dealer (~$30/gal).
    Back to the gate entrance - I want something comparative to a good automotive paint that will give me a good 10+ years. I also want to get it in a ďchassis blackĒ which is similar to satin or about a 30% gloss. Itís going to take about 3 gallons or so to paint this thing and at $125 a gallon, it will eat my budget.
    Iím leaning towards going to my local Kelly Moore or Sherman Williams and see what I can get there. Does anyone have any suggestions for me?
    Thanks.
    Dec 2005
    wisconsin
    836
    Valspar is making synthetic enamels and a catalyst to go with them. Its sold by Tractor supply and the like. Sprays well, available in gloss, semi gloss, satin, etc. Nice durable paint.
    Otherwise Hawthorne makes industrial Acrylic Enamel for automotive use. Prices are about 62.00 a gallon including hardener and reducer. Visit them at www.paintforcars.com
    Ive use both of these with good results.
    -Aaron
    Miller Dynasty 300DX
    Miller Dynasty 200DX
    Miller Spectrum 375 extreme
    Miller Millermatic Passport
    Miller Spot Welder
    Motor-Guard stud welder
    Apr 2007
    Sebastian, FL
    4
    generally nason single stage enamel is not bad paint, but it tends to fade bad. now you can go to single stage urethane nason which will hold up alot longer, make sure the prep is good. i like using dupont veri prime to etch the bare metal, some people love epoxy over etch. just make sure you use a proper breathing resp. cause of the iso in the urethane. oh yea you didnt say how big the gate was, but good hvlp gun with like a 1.2 or 1.3 tip will reduce paint usage..tony
    Clifton, NJ
    57
    Default Vinylast
    I have heard that Vinylast works the best for outdoor ornamental design work., it runs about $90 a gallon has a reel nice semi gloss black. You can get it from Kings.
    Apr 2007
    347
    Quote Originally Posted by MetalCrafter View Post
    Is that King Architectural Metal?
    Apr 2007
    347
    Quote Originally Posted by tony j View Post
    I have yet to use a urethane/epoxy paint. Will "white metal" be okay for the prep or would I still need to etch the metal with a special primer? One of the other problems I'm running into is that Nason and other good paints aren't available in satin or semi-gloss black. Almost all automotive paints are high gloss.
    The gate is 15'x6' and I'll be using my Sata with a 1.4 tip.
    Bath England
    15
    Dupont do a satin binder for their paints in which you substitute for the gloss ones. not sure about the other manufacturers you list cos we don't get them over here but might be worth talking to a local car sprayshop.
    Apr 2007
    Sebastian, FL
    4
    your sata, is it hvlp? im sure it is, but you never know, 3 gallons is alot of paint, not sure of the design...i really dont know anything about white metal, but with all the work going into this project i would not be cheap on the paint, stripping it will suck later when it peels. try a post in this auto body group, a lot of really nice people...tony
    http://autobodystore.com/forum/showt...ght=semi+gloss
    Apr 2007
    347
    I need to paint the gate and the surrounding pipe fence.
    Gate - 15'x6'
    Gate Posts - 6" pipe 15' tall with a 21' overhead brace
    Pipe Fence - 56' of pipe fence, 57" tall with 6 rails (4" post and 2 3/8" pipe rails)
    So, I'm guessing around 3 gallons and the Sata is an HVLP gun.
    Apr 2007
    Sebastian, FL
    4
    Quote Originally Posted by garybdavis View Post
    Gate - 15'x6'
    that makes alot more sense, tony
