Results 1 to 2 of 2
    105
    Default burning through with the spoolmatic 3
    i just purchased a old spool matic 3 today and was using it on some alum.
    the problem is i keep burning through.. i was useing 1/8 alum checker plate not shure what grade of alum tho ,, its on a mm251.. anyone know what settings i should have it at for 1/8'' and 1/4'' alum.?
    Jorgensen MFG.
    argonweld_bjorn@hotmail.com
    www.ehhitch.com
    May 2007
    Alberta
    135
    Smile starting point
    with 5356 wire, 22 volts and 550 or so wire speed. go like ****
