Page 1 of 3 123 LastLast
Results 1 to 10 of 24
    Default Dual Bottle Rack for MM251
    Has anyone made a dual bottlle rack for their MM251. Can you weld to the existing rack without removing it from the welder?
    jim
    Ocean City, Maryland
    951
    Quote Originally Posted by Trap Doctor View Post
    jim
    Our 251 came with a dual bottle rack, I didn't know they only came with one. As far as welding the rack with it on the welder I don't think I would. We weld on trucks all the time and because of the computer equipment we disconnect all the battery cables. So I would think the same would go for the welder. someone else on here might know better, but thats my 2 cents worth
    Scott
    HMW [Heavy Metal welding]
    British Columbia
    500
    Cool Disconnect the battery! why
    Hey HMW why would you disconnect the battery when you can use one of these.O ya and for anybody eles that reads this never weld on any vehicle with out this this will save your azz someday from replacing the computer or any other expensive electrical part $100.00 cda / us $65.00 ?
    951
    Quote Originally Posted by Darmik View Post
    Well, we disconnect the batteries because we don't have one of those . and ECMs are very expensive. What is it and where did you get it at. I assume it must absorb stray current or voltage spikes??? It looks easier than disconnecting 3 batteries. We not only have the trucks engine/trans ECMs but also radio [800 mhz] and computer equipment mounted in the cab. Caterpillar also recommends disconnecting the ECM even with the batteries disconnected.
    Scott
    Jan 2006
    Albuquerque, NM
    1,788
    jim
    I made this one for my MM210, I gave it to the guy who purchased the MM210 but it will fit the MM251 no problem and no welding required to mount it as it is a bolt on using the existing holes on the top. you will just need to get a longer axel to space the wheels out a bit. Disregard the part about me making a box, and the base has angle legs welded to the bottom and sized to fit and clear the factory tray. you may need resize the bottom tray to fit whatever size bottles you want to use. Hope this helps.
    Regards, George
    Coastal Carolina
    12
    I donít believe that I would weld on the welder out of fear of ruining something inside, but I might be wrong on this one. I would fabricate and attach trinkets without welding. I donít know if drilling additional holes would void a warranty. I would call miller before any modiication.
    951
    Default Darmik
    One of the guys in the shop found the surge protector you mentioned. Its $61.97 at "unigue truck equipment" or www.uniquetruck.com. Looks just like yours. We often wondered why just removeing the battery cables would prevent damage since there are lots of other grounds all over the place. And you know how voltage spikes are, they can go through anything. Guess thats why CAT says to disconnect PCM. We might have to try one of them.
    thanks for info
    Scott
    Oct 2005
    Bulverde, Tx
    1,244
    I made one for my MM210 based on George's plans...with a twist. Instead of making anything that would have to replace existing stuff, with the exception of the upper rack, I made it so to be easily removed and restore the unit to original equipment quickly.
    Basically, I made a dual tray to sit in the existing bottle tray. It is set up on risers so as to clear the wheels. I only use 150cf cyls max, so stability isn't a problem at all.....and I didn't have to mess with the axle.
    I even used scrap and leftovers I had at the shop to build it. Ran short of 2x2x1/8 angle and popped into Homey Despot to finish it up....that little 3' piece cost just as much as all the other stuff.
    FWIW, I did this two years ago and it is still working without any issues. Right now, I have one 125cf and a 150cf on it. Works like a champ.
    Don
    '06 Trailblazer 302
    '06 12RC feeder
    Super S-32P feeder
    HH210 & DP3035 spool gun
    Esab Multimaster 260
    Esab Heliarc 252 AC/DC
    17
    Default Dual bottle rack
    Go here: http://flickr.com/photos/ronnielyons
    Look at the right side of my cart and you'll see the dual bottles I mounted.
    Ronnie Lyons
    cog4150@hotmail.com
    N.C.
    362
    Ronnie....can you post up (in another thread) some more info on your 210 carrier...I like it....you may want to submit it to Miller for the contest.
    Mike
    George W. Bush was saving your butt whether you liked it or not!
    HH210 with SG
