Page 2 of 2 FirstFirst 12
Results 11 to 16 of 16
Thread: Latest Project.
    Mar 2006
    Ocean City, Maryland
    951
    Thumbs up
    Good looking trailer and I like the lights in the tailgate too
    Scott
    HMW [Heavy Metal welding]
    Apr 2007
    Havana, Florida
    50
    Very nice trailer!
    Jan 2007
    Montana, USA
    228
    Nice. How do you support the gate at the hinge when it is down!
  4. #14
    Sep 2006
    South Central Kansas
    58
    Trailer looks good, was also wondering about how you made your hinges and your latches for your tailgate? Also your cherry picker did you make it also if so could we see another photo or two of it?
  5. #15
    May 2007
    Tampa, fl
    6
    The first part of the gate is held by chains, like a truck tailgate. And the second part just tilts at the hinge to the pavement.
    Quote Originally Posted by Goodhand View Post
    Miller Econo Twin HF AC/DC / Gas Tungsten Arc.
  6. #16
    May 2007
    Tampa, fl
    6
    Quote Originally Posted by gnewby View Post
    The hinges are 3/4 bar drilled through the center with a 3/8 bolt through the center. 3 sections for each hinge, 2 welded to the main gate, center welded to the second gate. 8 hinges total. Had to grind a small clearance for the hinge not to rub on each gate. Works great, my Valkyrie interstate weighs 940 lbs, and my 200 lbs on it, the gate does not even flex when loading it.
