Results 1 to 8 of 8
Thread: Steel Max
    Central illinois
    98
    Thumbs up Steel Max
    This Saw Is A Steel Cuter It Has A Comparment On The Side That Catches The Slevers Of Steel When Cutting. An The Steel Doesnt Get Hot When Cutting. I Use It On Alum. Too It Is Pretty Handey In The Felid Where You Need A Clean Cut
    miller bobcat 250
    wc 115a
    spoolmatic 30a
    centery 250 mic
    2 lincoln 225 stick
    a 1954 hobart portable welder w/ willies jeep engine
    Apr 2007
    louisiana
    31
    they also make a good mag drill.have the original one that only takes the annular cutters but just recenty bought the new model that also takes a morse taper drill chuck or a drill bit
    Central illinois
    98
    Default Mag Drill
    Havent Seen That One Yeat We Got That Saw About A Year Ago From A Lawson Dealer That Was The First Time I Have Seen It Thanks For The Reply
    miller bobcat 250
    wc 115a
    spoolmatic 30a
    centery 250 mic
    2 lincoln 225 stick
    Ocean City, Maryland
    951
    Nice saw. First time a salesman demonstrated one, everybody stepped back thinking the teeth would come off. It was an evolution brand. Cut right through a piece of 3/8" plate, nice and smooth
    Scott
    HMW [Heavy Metal welding]
    Jun 2006
    Calgary, Alberta
    377
    I use both the saw and the older model drill at work.
    I find the saw works well for thin guage steel up to 1/4" plate when the collector cover is removed. If not, I find the chips pile up very quickly generating friction and heat bogging the saw down. I use rapid tap and machinist's coolant while cutting, it has seemed to keep the blade in good shape for quite some time now.
    The drill works very well although I wish it had tapping functions. It's the only mag drill annular cutter system that I've used that has its own lube feed. I like the fact that the drill has a safety device in it so that if there isn't enough magnetic grip the drill switch automatically shuts off. I've used it to mill slots 11/16" wide (using the bit like a router, the drill stationary, and material sliding in a jig) into 5/8" X 2" cold rolled steel. After attempting this totally incorrect use of the machine, the annular cutter and machine were in perfect condidtion. I'll try to post pics. It bores good quallity holes up to 2 3/8" by 2" deep.
    Jonny
    Dynasty 300DX
    Esab PCM 1000
    Central illinois
    98
    Default steel max
    sounds like this saw has been around for sometime now i just seen it a year and half ago and picked it up a year ago havent seen the drill that you jonnnytig and cajuncat is talking about.
    miller bobcat 250
    wc 115a
    spoolmatic 30a
    centery 250 mic
    2 lincoln 225 stick
    Apr 2007
    louisiana
    31
    The auto lube system is really nice.The new model also lets you select two different speeds which is real helpful on the bigger holes.Just used it today to drill some 1 7/8 holes in 1 1/2 with no problems.Will have to try and set the drill up by the holes and post a picture of it.
    Oahu, Hawaii
    2,469
    SteelMax as been at the Air Liquide tent shows over here in Hawaii for 3 (I think) years now. bought the chop saw last month and LOVE IT!!! Came with an extra blade for steel. He said I could cut a little alum with it, but if I did a lot, I should buy the alum blade (more teeth).
    bert
    I'm not late...
    I'm just on Hawaiian Time
