Results 1 to 5 of 5
    Salem ,Ohio
    3,975
    Cool Cast Iron Milling Machine table repair.
    This is a pretty common break on old milling machine tables. I fitted a chunk of copper bar under the tee slot to save machining later then i stick welded it with some 5/32 Viking Metals machinable cast rod i got cheap off ebay, wrapped it up in some insulation and let it sit a spell. It should clean up nice....Bob
    Feb 2006
    springvale me
    89
    Thumbs up
    Looks good Bob thanks for sharing
    garthswelding@aol.com trail blazer 301g with all the fixins:delta band saw dewalt chop saw craftsman drill press, sp-135 mm251 spectrum 375 suite case mig, tig w/hi freq. one welding truck.
    Mar 2007
    Oahu, Hawaii
    2,469
    Hey Bob,
    saw all your pics off your photo show...SWEET!!! 'Far as this table, top can be grinded down normally, but how will you grind down the sides to match the rest of it?
    thanks,
    bert
    I'm not late...
    I'm just on Hawaiian Time
    Sep 2006
    Wheeling
    169
    Bob
    Could you post a picture of the rest of the machine? You did a really nice job. I may have used nickle rods if this is really cast iron, just a thought.
    Jerry
    Salem ,Ohio
    3,975
    Cool
    Here is a pic of the whole machine. I just welded it for the owner and he is going to have it reground. Internet welding job . I used cast iron welding rods that are 100% machinable and the color should match pretty good...Bob
