    Apr 2007
    4
    Default Trailer Fender height
    Thanks for the help on the tongue as it's almost done...Next question Is I need to replace the fenders that are gone anyway this is a car trailer with tandum axles. At what height should I put them above the tires?? Thanks Again
    Vero Beach, fl.
    761
    Default fender height
    When mounting the fenders on my trailers I use about 4 inches of clearance above the tire. Dave
    105
    4'' is a good preferance
    but you should use the distance between the axle and the frame if it is underslug springs. i figure then u can overload your trailer alll the way and still be clear on hight between fender and tire
    if it is an outragous distance use the 4'' tho..
    i tend to use little piece of 4x4x4'' block of steel i got laying around to get an acurate space.
    Jorgensen MFG.
    argonweld_bjorn@hotmail.com
    www.ehhitch.com
    Vero Beach, fl.
    761
    Another way to figure fender height on a tandem axle is to measure from the bottom of the frame to the bolt holding the spring to the equalizer. What ever that distance is just add a little more for clearance. This way you will know the true amount of possible spring travel. Dave
    Correction: after re reading it I didn't explain properly
    Should say: measure from bottom of frame to the bolt holding the spring and shackle together, not the bolt from the shackle to the equalizer. Dave
    Last edited by dabar39; 04-28-2007 at 09:20 AM. Reason: didn't explain it correctly
    105
    cool i never knew that one
    Jorgensen MFG.
    www.ehhitch.com
    Apr 2007
    Havana, Florida
    50
    Default Fenders
    4 inches should work, just make sure you re-enforce the fenders good because that will be the first place someone will step to get up onto the trailer and first thing you know they'll be rubbing against the tires once they get bent down. Good Luck!
