Results 1 to 7 of 7
    Dec 2005
    6
    Default TIG Weling Machines
    I have had some experience with MIG and OXY but would like to try TIG welding. I am a hobby welder and would like to find a used machine. So far no luck. Are they that hard to find ? Any suggestions? Thanks.
    Jan 2006
    Antigonish, Nova Scotia, Canada
    33
    E-bay always has some good used machines. Check it out.
    Evansville, IN
    2,348
    I would look into a maxstar 150STH complete kit is about 1400+-. I own a Dynasty 200DX and if aluminum is in the picture then it is my first choice but it is overtwice as much. Sources I recommend are www.brwelder.com and www.cyberweld.com
    Happy hunting,
    Plymouth, MI
    475
    Good GTAW machines really hold their value. Those that get deals on used are few and far between and it's usually a family member or friend that gives them the great deal. Usually the better used machines are within a few dollars of new, sometimes on Ebay I've seen used machines go for more than the discount prices from the sources that pjseaman listed.
    Decide on your budget and then get the best you can afford. The Maxstars are really great machines if you don't need to do aluminum.
    Good Luck on your decision!
    Bob Sigmon
    ___________________
    Dynasty 200DX w/ Coolmate 3
    Miller Passport
    LMSW-52T Spot Welder
    A/O Setup with Meco Midget
    Miller Big Window Elite
    Quincy QT-5HD
    Jan 2006
    Albuquerque, NM
    1,788
    Having owned two Maxstar tig welders I concur with the other comments. If you are doing MS of SS they really are hard to beat. If you need/want to do aluminum then you will need to spend more money, and there are several AC/DC tig welders to chose from.
    Regards, George
    Nov 2005
    986
    if you have no need for aluminum i would go with a maxstar 150stl or if you want to upgrade go with the maxstar150sth.
    S.W. Pennsylvania
    2,250
    Quote Originally Posted by Bob Sigmon
    When I bought my tig I started out looking at used ones and could not find anything to convince me not to buy new. Like you say, they hold there price really well and for the little bit of a discount its not worth loosing any warenty time.
    My sincere thanks , Pete.
    Pureox OA
    Westinghouse 300 amp AC stick
    Miller Syncrowave 250
    Hexacon 250 watt solder iron
