I have a chance to look at a Hypertherm max 20 that's used but in good condition. Is this too old of a unit for replacement parts?
I believe the asking price is around $100 give or take, yes or no for the price?
Will this unit cut thru mesh without a restart everytime it cuts thru a section?
What would the material thickness limits be for a clean cut?
Thanks in advance.
Results 1 to 10 of 24
Thread: Used Hypertherm Max 20
09-22-2007, 01:45 PM #1
- Mar 2006
- 124
09-22-2007, 04:06 PM #2
- Mar 2006
- 124
Anyone?
I have less than a hour before the business closes besides other people have shown an intrest.
Parts still available should I buy it?
09-22-2007, 05:02 PM #3
- May 2005
- 600
I'm probably too late, but consumables are still available.
09-22-2007, 05:27 PM #4
- Mar 2006
- 124
I just got back, it's still there and in an estate antique store no less.
On the back is an inspection tag dated 11-76 plus a filter/regulator.
My fear was replacement consumable parts for a 31 year old machine.
My guess is clean cutting up to 3/16" material and thicker with lower quality.
This unit had a $125 tag marked down to $115 I bet he'll go lower, **** a good condition Skillsaw for $40.
I'll talk to him on tuesday and thanks for the information.
09-23-2007, 08:38 AM #5
- May 2005
- 600
Carl, if you do score it, Hypermax.org, seems to have the best selection of parts (torches and leads as well as consumables), and may have internal parts as well.
09-23-2007, 09:33 AM #6
- Mar 2006
- 124
Quick answers with great people makes this forum the best around, thanks for the parts address. I know a small plasma machine but then it's for home hobby use like the 350 Synchro, 251 w/30A, lathe and Bridgeport.
09-23-2007, 03:56 PM #7
- May 2005
- 600
believe me for that price i'd camp out to score it, there is one on E-bay going for $600 "buy it now" and it's broken (needs work).
it appears the MAX20 uses the PAC110 torch, the same torch is used on the Hypertherm PowerMax 350 & PowerMax 380(?) so consumables may be available at any LWS.
09-23-2007, 04:18 PM #8
- Mar 2006
- 124
What is the air pressure required to run this machine plus the clearance between the torch and and the materal cut? I know nothing abot plasmas.
Will it sever .200" material, quality not an issue plus what is the maximum thickness for a quality cut?
When I go to test it what thickness material should I use and how many seconds per inch should I expect.
Thanks everyone.
09-23-2007, 04:24 PM #9
- Mar 2006
- 124
When I go to test it what thickness material should I use and how many seconds per inch should I expect?
Thanks everyone.
09-24-2007, 06:30 AM #10
- May 2005
- 600
pressure 60-65PSI
sever 0.25
quality 0.187
rated 0.125
speed? 20-21" rated, 15-16" quality, SLOW" sever. these speeds may differ until you get comfortable.
stand off 1/16" maybe a lil' bit more. you could drag this machine, but it's harder on the consumables (double arcing)
manual: https://www.hypertherm.com/library/f...)/800710r4.pdf
PAC110 repair instructions: https://www.hypertherm.com/library/f...)/801200r0.pdf
literature email request: literature.request@hypertherm.com
street address and tele.:
Hypertherm, Inc.
Etna Road, P.O. Box 5010 Hanover
NH 03755 USA
603-643-3441 Tel (Main Office)
800-643-0030 Tel - Toll Free in USA and Canada
pdf of torch consumables and parts:
http://www.hypertherm.com/languages/...X20_oldrev.pdf
