Thread: Millermatic 35
    3
    Default Millermatic 35
    I'd like to know some info. about my welder. My welder is a Millermatic 35. I'd like to find out what my welder can do. what can it weld and how thick or tack weld. Please tell me the best way to set up the machine . (Submitted by: jess from NC)
    3,954
    I had a few MM35's and they are pretty close to my MM185. It should be able to do 3/8" plate with no problem, just watch the duty cycle so you don't cook the machine. I would use .030 wire but thats up to you. What's you plan for gas? CO2 or 75/25 either one would be fine...Bob
    3
    thank you Bob
    Apr 2007
    348
    The Millermatic 35 has been my main shop welder for over 10 years now. I can't tell you how many 30lb rolls I've run through it as I've lost count. It was a staple of Miller's sales for several years back in the late 70s and early 80s. I keep wanting to get a new, shiny machine, but this one just won't die.
    I run .035 with a recently updated Benard Centerfire gun and 25/75 CO2/Argon gas. You can tell the year it was made by the serial number - check with Miller.
    Last time I looked, parts were still available although the old, original guns weren't. Although the drive design isn't perfect, you can still upgrade to the latest Centerfire style.
    It's a good welder for up to 3/8". I've welded four foot long beads with 1/4" plate on the #4 tap without overheating it. Note that it does not have an automatic shut-off when you get it too hot. So, you have to feel the tap cable by hand if you think you are on the high side of it's duty cycle.
    Millermatic 35
    Miller TB302G
    Ellis 1800
    Smith & Victor Torches
    Optrel Satellite
    Arcair K4000
    Ingersoll-Rand 175CFM Diesel Air Compressor
    Home Made Welding Trailer
    Browns Valley, California
    1,713
    Jess,
    You can download the manual from this site (click on the "SERVICE" tab at the top of the page), or, if the manual is no longer in the archive, you can order a paper copy for $15.
    Hank
    ...from the Gadget Garage
    Millermatic 210 w/3035, BWE
    Handler 210 w/DP3035
    TA185TSW
    3,954
    One other thing is the MM35 is the grand daddy of the modern day mig, they were the first small mig that was affordable. If it wasn't for the sucess of the MM35 we all wouldn't have migs to play with at home...Bob
    Default Mm 35
    Hi ....
    I Need A Spool And Hub For My Old Mm35, But Do Not Have A Part Number To Order It..... Can You Help Me With That? Would Appreciate It A Lot..... Thanks!
    1,713
    Welcome !
    FYI, the owner's manual is available as a free download. Just click on the "service" tap at the top of this page.
    The spool hub PN is 058 428.
    Hank
    TA185TSW
    Midwest
    765
