Page 1 of 3 123 LastLast
Results 1 to 10 of 21
    S.W. Pennsylvania
    2,249
    Default Fender brace, 1st milling project
    If Bulldog is still around, he will get a kick out of this one.
    I finally got my turn tables mounted and most of my tooling issues straitened out. The first pic is a drawing of the piece.
    Second pic is making new jaws for the vice to compensate for the base that is worn off square and the excessive jaw lift when its tightened.
    The next pics are just the order of progress. I squared the sides, flattened the face with the fly-cutter then squared the ends.
    Now I'm debating how to continue now that the plates are flat,true and parallel. My plan of attack is to cut the to the widest length and width detentions, then drill and tap the bolt holes.( the bolt holes are not clearly marked on the drawing but I'm sure you can figure out where they are.) Next will be to drill the 1.625" hole with the boring bar, then put it on the rotary table to shape the outside dimensions and last I will cut the slot in the clamps.
    If anyone sees a problem with my plan, please let me know. This is my first project.
    My sincere thanks , Pete.
    Pureox OA
    Westinghouse 300 amp AC stick
    Miller Syncrowave 250
    Hexacon 250 watt solder iron
    S.W. Pennsylvania
    2,249
    This is a more descriptive drawing of the brace. I couldn't find it when I started the first post, then it popped up when I went to check a dimention.
    Oh well.
    To fill you all in, this is part of my headlight project, hears a link to it.
    http://www.millermotorsports.com/mbo...dlight+project
    Pureox OA
    S.W. Pennsylvania
    2,249
    Well, I finally finished the braces.They came out real good except for the corner rounding, I'm sure its due to using a cheap Chinese rounding mill. I could see it did not turn true and it felt like only one of the 4 flutes was actually cutting metal.
    The inside radius and all the flat stuff is very smooth but the corner rounded portions feel like snake skin. The first picture shows this very well, although the piece is not complete. The other pics are the finished pieces. I'm not sure what to do about the rough texture of the rounded parts to make them smooth without distorting the shape. Was thinking maybe hand sanding with 320 paper?
    Any suggestions welcomed.
    I just hope when I finish this project, my health will be good enough to still ride. I had to go to the doctor after testing out the riding mower for the neighbor kid that mows our lawn now.
    I have pictures of the whole process of making these if any one is interested in seeing them
    Pureox OA
    Ukiah, Ca
    277
    Nice work, Briar.
    AutoArc 230 (MM 210)
    3035 spoolgun
    Spectrum 625
    Dialarc HF w/Coolmate 4
    S.W. Pennsylvania
    2,249
    Quote Originally Posted by bob_e95482 View Post
    Nice work, Briar.
    Thanks, any suggestion on what to do about the snake skin texture on the corner rounded parts?
    Pureox OA
    now in Orlando!!!!
    557
    Briar, Scotchbrite wheel [#9N] for bench grinder,for the snake skin removal, it does a great job of deburring, sometimes called a convoluted wheel. about 50 bucks but lasts a very long time is is great also for deburring edges, hope this helps, Paul
    More Spark Today Please
    Glen N.Y.
    902
    Hey guys,
    Pete,
    The Bulldog is still around... Things here have been real busy. (were still going 7 days a week) I don't have alot of time to respond much any more but I still try to read most of the post.
    Your work looks great! I have been keepinng up with your milling machine saga. Looks like you got things worked out and your definitly moving in the right direction. Good job!
    I'll try to get in here more often.
    See ya,
    Bulldog
    5 Passport Pluses
    2 MM 212's
    MM 210
    MM 251 MIA
    MM 350 P w/Python
    w/ tig runner
    Trailblazer 302
    12RC w/meters
    Spectrum 1000
    Spectrum 2050
    2 Black BWEs
    Joker BWE
    Star & stripe BWE Digital
    2 star & stripe xlix's
    REAL TRUCKS RATTLE
    CUMMINS BABY
    lramberson Guest
    Pete, Project looks great, I like the textured look, it would be the custom touch for me.
    I would like to see the whole process, so I will be the first to ask for the full photo essay.
    Raymore Missouri
    1,907
    Good job..............most that have not machined before have not a clue what it takes to make a part like that. When I made my cnc table, I'm sure glad I had a lathe and mill.
    Miller 252 Mig
    Miller Cricket XL
    Millermatic 150 Mig
    Miller Syncrowave 200 Tig
    2-O/A outfits
    Jet Lathe and Mill
    Jet 7x12 horz/vert band saw
    DeWalt Multi Cutter metal saw
    Century 50 Amp Plasma Cutter
    Propane Forge
    60" X 60" router/plasma table
    I'd love to see the pics of the whole process. What mill is that?
