Page 3 of 8 FirstFirst 12345678 LastLast
Results 21 to 30 of 73
Thread: dump bed hoist
  1. #21
    Oct 2005
    Calgary, AB
    52
    Good to hear!
    Glad I could help. Hey, make two and send me one
    The difference between No One. and No. One is where you put the period. John Force
  2. #22
    5
    Hi Silverback,
    Yes sir, I would love to see those plans still...
    You can try to send them to bert59000@yahoo.com...if that won't work I'll figure something else out.
    Thanks a bunch,
    Slag
  3. #23
    Oct 2005
    Calgary, AB
    52
    Hey Slag.
    Looks like they went throu on my end, let me know.
  4. #24
    5
    Hi Silverback,
    No such luck for me...
    Checked my email and there's nothing there. I'm wondering if Yahoo allows transfers that large?
    When I looked again the address was goofed-up...it included the the " if " behind it. It should have been,
    bert59000@yahoo.com
    If this won't work, does anyone know of a place I can open an email account that will allow a transfer that big?
    Will AOL? Netscape?
    I guess I'll do some homework...
    Thanks,
    Slag
  5. #25
    5
    Hey Garth,
    Were you ever able to find a set of those prints around the shop?
    I'd love to build the sissor's hoist if I can.
    Otherwise, just finding a place to buy one would be great...
    Party on...
    Slag
  6. #26
    Silverback,
    Would you mind e-mailing me a set of plans? I've been wanting to make a dumpbed trailer for sometime now. A set of plans would help me out a lot. twin_kings@hotmail.com
  7. #27
    Feb 2006
    springvale me
    89
    Hey slag the only one I could find was all stuck together got rained on when the roof leeked but one of the guys at my day job is looking through his old stuff to to see if he can find one of the older prints . the place I work during the day sells them however that would be a long drive. If we cant come up with a print some where Northern tool sells a cuople of them in there master catolage for a lot less than you could buy one at a truck eqipment shop . just looked it up in the NT cataloge and they have 2 different ones 4000lb sizzer hoist for 939.00 that is with all the hydrolics and controls this is for like a p/u. Then there is one for one tons and heavy trailers this one goes ten ton and is 1799.00 might be cheaper to get one of these but I will keep looking for another set of plans and will get back to you soon. Ruff geuss NT beets the shop I work at daytime buy 1250.00 on the first hoist I mentioned Will get back to you soon on the plans though sorry it is taking soooooo long to come up with a set.
  8. #28
    Feb 2006
    springvale me
    89
    Hey slag what is the hiost going to be put on if cant come up with the plans and buying one is to many $ how about a tellescopic ram mounted up front of the traler or body? much less$ and no plans needed. they make a insert for trucks but you could use the same principle to make one or to make a trailer that way all you need is the cylinder and a electric hydrolic pump and if its a trailer a couple of winch plugs . or cuold make a strate push sub frame for either . but will keep looking will get back with you soon
  9. #29
    Oct 2005
    Calgary, AB
    52
    Hey Slag, Check your email again. I simply forwarded it to the corrected address.
    Samething for you NorthernLights.
    If they don't come through, I'll burn it to a disk and send it to you. Just PM me with your address details.
    Silverback
  10. #30
    Silverback,
    Thanks for the plans. Look great, give me lots of ideas for my project. I'm trying to find a high flow hydraulic pump for some bigger cylinders. I think somewhere like 3.5 - 5 GPM. I might look at some hydrualic lift gate pumps. I'll also check those links in the info you sent me.
    Thanks again.
