Results 1 to 10 of 16
    Apr 2007
    22
    Default Air dryer for portable compressor
    I am buying a Makita MAC2400 air compressor to provide air for a Hypertherm PowerMax 30. The whole idea here is something portable. And, that brings me to my question: I understand that dry air is important in running a plasma cutter and with a small compressor I will need to do something to dry the air before it gets to the cutter. In reviewing lots of air compressor dryer threads here and on other forums I see lots of nice shop mounted systems with miles of piping, drains and refrigerators to dry the air but none of those solutions are remotely portable. I see a few filters for >$100 that seem to be one solution but I came across several examples of very small in line filters for much less $$ (like $20) that were intriguing. Are those simply terminal filters supposed to work with a separate air dryer or can these function as the primary drying device?
    I don't anticipate needing more than 15-20 minutes of cutting (max, mostly much less) at a time. Work would be outdoors in summer conditions in New England so humidity is somewhere between that in Houston and Phoenix.
    Any thoughts?
    Oct 2005
    Benton, IL
    757
    The smallest, most portable filter? The HTP Super Dry, $6.99
    If you want the Super Dry to last any length of time, install a Motor Guard filter in line first. Around $75, click here.
    Nothing else even comes close to those two products.
    Barry Milton
    ____________________
    HTP Invertig 201
    HTP MIG2400
    Miller Trailblazer 302, Spoolmatic 30A, Suitcase 12RC
    Clarke Hotshot
    Quote Originally Posted by Island View Post
    Any thoughts?
    humidity in Houston is significantly greater than in Phoenix. some days its just a fog coming out of the air lines. at that point you need all the piping and "non portable" stuff just to dry it. however, i have used the small inline filters , such as those above, for painting with very good success. i know youre asking about plasma cutters but spraying automotive paint also requires dry air.
    Apr 2007
    22
    Quote Originally Posted by 10sec.et View Post
    Actually from my reading I think painting probably requires even drier air to work than plasma does. I think the issue with plasma is not so much whether it will cut but rather the life of the consumables if you don't adequately dry the air.
    Sounds like if you can function in Houston with these in line filter combos that I should easily be able to do that in Rhode Island.
    Apr 2007
    22
    Quote Originally Posted by precisionworks View Post
    Thanks, I will give them a try.
    Apr 2007
    22
    OK, in looking up the linked website at ArizonaTools, I find that there are actually four identical looking filters that all have the same replacement cartridge. One is labels as being for plasma systems and is more $$ but no explanation of what the differences are between the M26 (plasma), M30, M45 and M60 filters is. If they have the same media/filter cartridge, how different can they be?
    Dec 2004
    21
    Yep, I have been thinking about one for several months and noticed the same thing. My thinking the way to go is with a M45 (a M30 w/ 2-723 cart.). Intresting note, the M26 Plasma filter flows 2600 cubic feet per hour. The M30 flows 45 cfm x 60 min = 2700 cubic feet per hour.I think both are rated for flow @ 80 psi. Bracket might be different, big deal.Welding suppliers are asking $105 and up for the M26. Maybe they are trying to hood wink us plasma guys.
    Oct 2005
    Benton, IL
    757
    The M26 is 1/4" NPT in & out, which limits the unit to 45 CFM.
    The M60 is similar, uses the same element, but has a straight throug piping design & 1/2" NPT in & out. It flows 100 CFM.
    The other two items are Filter Kits with contain two spare elements.
    Barry Milton
    HTP Invertig 201
    HTP MIG2400
    Clarke Hotshot
    Apr 2007
    22
    That makes sense but doesn't jibe with pricing structure. The items with the extra filters cost the same as the M60 and actually cost less than the M26. Is there any reason not to get one of the kits with the added filters and simply use step down fittings to adapt to the more common 1/4 inch NPT fittings found on the small compressors?
    Apr 2007
    22
    I called Motorguard and got the following info from a very helpful lady whose name I forgot to ask:
    1) The M26, 30 and 60 are all essentially the same filter unit using exactly the same cartridge.
    2) The M45 is the M30 with two extra filter cartridges (and oddly priced below the M30 alone!!)
    3) The difference between the M26 and M30 is that the M26 has an extra nut and bolt as part of it's bracket to allow it to be secured to a plasma cutter.
    4) I believe she told me that the difference between the M30 and M60 is limited to different air IN/OUT port locations and NPT fitting size (M30 1/4 inch, M60 1/2 inch), nothing else. M30 in/out are on top and I recall she said something about the M60 having the out line on the bottom.
    She also mentioned that they recommend 25ft of line between the compressor and the filter to allow the air to cool and water to condense before reaching the filter.
    Finally, you should not leave the used filter element in the cartridge but rather take it out and leave it open in the room to dry after use. Even in the humid summer weather that is preferable and no special efforts need to be made to protect the filter elements from ambient humidity.
    Bottom line: the M45 package is the way to go.... Which is nice as that is the least expensive and has the extra filter elements. http://www.arizonatools.com/tools/ai...detail/JLMM45/
    I may try some of the disposable filters first to see how long they last before I bother to rig one of these bigger canister types though. I called HTP and ordered some of the super drys. Motor Guard also makes a disposable DD1008 filter that has a color change agent so you can see when the filter needs to be changed and it is small enough to put in line right at the plasma cutter without mounting.
