Results 1 to 7 of 7
    Clearwater, Fl
    6
    Default My Entertainment Center Table
    Hello All,
    Here is my first metal working project!!! I used my Miller syncro 200!!! WHat do you think??
    Alex
    Feb 2006
    19
    I like it, how did you fasten the aluminum shelves?
    Suffield, Ohio
    344
    I like it. I'm also wondering how you mount the diamoned plate.
    Ocean City, Maryland
    951
    Looks like the floor is carpeted? How do you keep that from getting burned up.......
    Scott
    HMW [Heavy Metal welding]
    Central illinois
    98
    Thumbs up garabato25
    nice job on your entertainment center. no more tangle wires. ha
    miller bobcat 250
    wc 115a
    spoolmatic 30a
    centery 250 mic
    2 lincoln 225 stick
    a 1954 hobart portable welder w/ willies jeep engine
    Clearwater, Fl
    6
    Smile thanks for the replies
    Hey guys,
    thanks for the replies...I cut a slit into the metal backbone a 1/4" thick parallel to the ground and just slide each shely in. I also added a small piece of angle iron below each shelf to help support the weight.
    Cheers.
    Alex
    Oahu, Hawaii
    2,469
    A-w-s-o-m-e!!! Are you going to make a diamond plate back to hide the wires? Per HMW...did you lay fireproof canvas over the carpet when you welded it together???
    bert
    I'm not late...
    I'm just on Hawaiian Time
