Page 1 of 3 123 LastLast
Results 1 to 10 of 25
    Ocean City, Maryland
    951
    Default Welding anodized aluminum
    Anybody with any experience welding anodized aluminum? I have welded lots of aluminum things but never anodized. Some that I have looked at looks like the weld is painted with something. What do they "paint" it with. Almost looks like primer but I'm sure thats not what its, it matches the anodized aluminum pretty well. Also, any info on the welding process would be helpfull.
    Scott
    HMW [Heavy Metal welding]
    Delmont, PA
    290
    Default Anodizing....
    Hey HMW,
    Been welding aluminum many years now. Anodizing is simply an electrolytic process that adds a protective coating to the aluminum. To get the best welds, the anodizing should be removed with a flap sanding disc (40-60grit) on the welded areas. 4043 will give the closest color match and 5356 is close. The alum. then can be re-anodized, if necessary, or if cost-prohibitive, coated with a clear acrylic coating....Denny
    Midland, Mi.
    313
    I have known a few fabricators that after grinding off the anodizing would weld the part then use silver pray paint to coat it afterwards. Maybe it is just paint on the welds you see.
    now in Orlando!!!!
    559
    The problem with 4043 as I understand, is if you "re anodize", it will turn black. I have not personally done this, but have read this in many sources. I would imagine you need to increase the positive side of the wave for better cleaning action to remove the oxide coating better. Hope this helps, Pual
    More Spark Today Please
    951
    Yes, i've been told that 5053 is best if you are going to anodize it. What I have seen is towers that already are anodized and have been welded. I guess you can bend the stuff with out the anoidizing cracking. The welds were definatley made after it was anodized. Maybe it is a clear paint on the welds, it looks good. Also I have read you dont need to clean off the anodized, but can weld right through it. Also read about using a on/off switch on the torch for this process. I have a foot pedal now and have seen thumb controls but not and on/off switch. I see I'm going to have to find some scrap to play with. I recently extended the pedestals on 2 boat seats. I had to sit in teh floor of the boat with the pedal under my leg, worked Ok but thumb controls might be easier I dont believe they were anodized as it welded pretty easy. Maybe a clear coat like wheels or something but not much. I painted the weld with "aluminum" colored rustoleum paint and looks pretty good. of course they are under the seat so you really cant see them very well, but still didn't want the weld to corrode. The tower in this boat is awesome looking.
    Thanks for the comments
    Scott
    now in Orlando!!!!
    559
    hmw, if you set the welder to the max amp you want, you can use the thumb control as an on/off, just go all the way with the switch...Paul
    Oahu, Hawaii
    2,469
    HMW,
    Can you post some pics of the boat tower and the welds?
    thanks,b
    bert
    I'm not late...
    I'm just on Hawaiian Time
    951
    Here is a couple of pics of the Tee top. The welds are very nice, but i would like to know what they painted over the weld with. Looks nice. sorta gray in color. The seat pictures are where i raised the pedastels 5". Kinda hard since the aluminum pedastel has grooves all the way around and they could not be removed from the boat. Also it seemed like they were clear coated, sorta like a wheel, so when I cleaned off the area to weld you could tell the clear coat was removed. Owner was happy with new "higher" seats. Talked over with owner and he agreed to just paint over clear coat removed area with "aluminum colored" rustoleum paint
    Scott
    951
    One more pic, just sorta figuring out this attachment thing, had to make the pics smaller. The grooves in the tube are for the seat base to lock on.
    Scott
    ****inson ND
    557
    Talking
    Trigger switches are great for out of possition welding but you bassicly have to forget about having that on demand control of your amperage. It's a bit awkward at first but easy to get used to if you have GTAW experience. Out of 50 - 100+ GTAW machines at work we have only 3 - 4 foot pedals since almost every thing is out of possition. By the way great work.
    Hope this answers your question about trigger switches.
