This is a set of forks that we made that attaches to a front loader.
Results 1 to 10 of 13
Thread: fork attachments for a trackor
03-28-2007, 07:42 PM #1
miller bobcat 250
wc 115a
spoolmatic 30a
centery 250 mic
2 lincoln 225 stick
a 1954 hobart portable welder w/ willies jeep engine
03-28-2007, 09:31 PM #2
Nice job! Wish I had room at home to do stuff that size
I'm not late...
I'm just on Hawaiian Time
04-19-2007, 04:58 PM #3
- Sep 2006
- 6
Fork Material
Terry, I was wondering wwhat you made the forkd from? They are tapered like a real forklifts.
04-19-2007, 06:52 PM #4
They can be purchased with the top pins like that.....my question is did they come with the holes in the tips or did you modify them? Reason I ask is I have seen owners drill them and have also seen the results.....drilling is better than a torch but still not good.
MikeGeorge W. Bush was saving your butt whether you liked it or not!
HH210 with SG
04-19-2007, 07:22 PM #5
84zmike
the fork on this attchment is off of a 10.000 or 12.000 lbs forktruck.the holes was already in them. and cut in.i do agree with you they should be drilled.the pins i made out of 1 5/8 shaft and 2in pipe thick wall. thanks for the reply.miller bobcat 250
wc 115a
spoolmatic 30a
centery 250 mic
2 lincoln 225 stick
04-19-2007, 07:22 PM #6
Cool looking forks. Nice job....The forks them selves look like they were forks off a fork lift. I bought a set once from a Hyster dealer and made the back of them fit a Bobcat carriage. AS far as the holes, your right 84Z your not supposed to put holes in them. We can't have them with holes in them where I work [OSHA] .But......................All the farmers here have them that way, including ours on our Kubota and I haven't seen one break yet. Unbelieveable how strong those forks are. At work we move trailers with them, so we made Pintle hooks that slide over the end, with a tee screw to clamp it and a piece of chain to the carriage.
Scott
HMW [Heavy Metal welding]
04-19-2007, 07:42 PM #7
hmw
the farmer is useing them to onload and load those big bags of seed.i think they are around 3600lbs.he got a buddy that got him the forks for nothing.he said the company puts new forks on every two years. i am trying to get one more set.miller bobcat 250
wc 115a
spoolmatic 30a
centery 250 mic
2 lincoln 225 stick
04-19-2007, 07:44 PM #8
OSHA is the very least of my worries....I work for a Cat dealer in the industrial div. field service.......the holes don't bother me so much as the ones that have been used to hold a piece of metal that is being cut with a torch .....the forks are heat treated and I have seen the results of welding and cutting on them.......I was at a fab. shop that uses there's as a fixture.....should have seen the look on the guys face when I explained it to him....... I asked for a piece of heat treated stock and when he handed it to me I asked for an o/a set up....we walked over and I picked up the torch and lit it....he asked WTF did I think I was doing...I then asked him why I shouldn't heat it with a torch and put it back in there stock....he stopped right after he got to the failure issues of it
(I was asked / told not to come back)
HH210 with SG
04-19-2007, 07:56 PM #9
Nice job,But, not meaning to critisise but the weak link you have there is the thin wall pipe to attatch onto the shaft where you adjust your forks. We have done many sets similar to yours & that should be 3/8 -1/2"wall tube.No way would I load seed & have done a lot of it with ours with that.Otherwise looks excellent.
04-19-2007, 08:10 PM #10
metal doctor
i cant get my pic. big enough to see good. but the pipe is thick wall 3/8. thanks for the reply.miller bobcat 250
wc 115a
spoolmatic 30a
centery 250 mic
2 lincoln 225 stick
