Results 1 to 10 of 10
    Feb 2006
    25
    Default Welding a sump to a gas tank....
    Hey guys I need to weld a sump to the bottom of a gas tank for my car. I have a dynasty 200 and was wondering what type of rod would be good for this type of job? Thanks guys! By the way both pieces will be new so no fire hazard
    Dynasty 200 DX
    Match the filler to the base metal. Aluminum, stainless, or carbon steel. It is that easy.
    Feb 2006
    Westland Mi
    10
    I have been using silocon bronze rod ( not sure of the spelling)
    with very good luck for gas tank sumps
    Home of the 9.29 street driven pump gas Chevelle
    www.beebemotorsports.com
    Apr 2007
    Lebanon, PA.
    5
    I'd use ER70S2 1/16" with a 2% 1/16" Tungsten. Good luck!
    Steve
    Alaska
    732
    Quote Originally Posted by SPI View Post
    Steve
    What if the tank is aluminum? or PVC
    TJ
    356
    Quote Originally Posted by Fat-Fab.com View Post
    TJ
    JB WELD!
    haha, but seriously, if you have an aluminum tank get an aluminum sump (or make one) and weld as usual, steel use er70s-6
    mm210
    maxstar 150
    Lake of the Ozarks MO
    3,593
    TJ
    Then you would need to be an "expert" (that is if you stick with that combo!)
    Miller 30-A Spoolgun
    Miller WC-115-A
    Miller Spectrum 300
    Jun 2005
    Nesconset NY
    74
    Default Solder it
    I have always taken them to the radiator shop and had them soldered.Had three done all the same way.
    Aug 2004
    Milan Michigan
    1,773
    I'd use my 110 mig welder with .023 wire.
    If looks are a little more important than do what Beebe Motorsports said silicon bronze tig filler.
    Jun 2006
    Maine
    732
    Quote Originally Posted by 427FAB View Post
    I'd be iffy on soldering it unless the sump was crimped into the tank... but that's just me.
    Bobcat 225NT
    Cutmaster 52
    Lincoln Weld-Pak 100 buzz box
    Caterpillar TH63
    '07 Kawasaki ZZR600
