Results 1 to 10 of 16
    Nov 2005
    Central Al
    8
    Default Weld/ Coat hanger
    I've heard many time of "Old Timers" welding with O/A using bare(no flux) coat hanger wire as 'filler'. Was this ever an common/widespread practis?Was the technique practical?What were some of the applications?
    I have never seen anyone imploy the method. I'd like to get some 'firsthand' info/comments.
    TIA, AL
    Nov 2005
    Toronto,ON
    22
    Default Coat hanger Rods
    Probably lots of welds have been made with coat hangers as filler rod, I know I used plenty in the fifties, going to school and money was tight. Nothing was critical though, just exhaust and maybe some bodywork. Today I don't think you'll find too much of that going on as rods are pretty inexpensive and there sure as H. is a lot more money around these days.
    Bought a good supply of 1/8" and 3/32" rods about 1981 and still workin' on 'em.............they never go bad.
    Nov 2005
    2
    The first time I saw it done was in a muffler shop and they were using the process on my car. To top it all off he used a pants hanger with the velvet type material coating to keep the pants from slipping. I wigged out when I saw what they were doing......turned out the exhaust system rusted away before the weld gave out. Still wouldn't trust that type of weld on a critical joint though.
    Nov 2005
    Green Bay, WI
    65
    I saw the whole coat hanger thing used in a body shop I worked at this summer. It was pretty cool. I didn't know you could do that.
    Vernon Ct
    117
    I have used it to plug holes that need to be re-drilled in the same spot. I was told the coat hanger did not get hard like the regular weld wire so it was easier to drill. A good drill will cut either of the 2. It welded good anyways. I don't think I woild use it as a comon practice. The right wire is cheaper than a law suite.
    Mike
    MD Welding & Fabricating L.L.C.
    Nov 2005
    986
    its very simple: Will it work? yes why yes it will. Will it be a good sound weld? No it will be near as strong as using the correct filler.
    1,258
    Quote Originally Posted by lilredex
    as long as you keep them warm and dry, rust is the only thing that will wreck them.
    Dec 2005
    375
    Default clothes hangers
    My brother used them a lot..I have too with good results but i prefer a brazing rod for most things if I'm going to be using a torch.
    Farris
    Nov 2005
    13
    I was told to never use them where strength was required because coat hangers are made of the crappiest steel alloys.
    Dec 2005
    wisconsin
    836
    Just for grins I had some coat hangers scanned for composition. An old one from about 1940 from my grandfather has almost identical composition as the old Linde #7 rod. A new Imported hanger from Wally World has the composition of some form of Asian monkey dung as best as we can tell. And people wonder why we buy American.
