    asheville n.c.
    618
    Default motorsports message board
    i cant get into the other board. ive registered reregistered and reregistered and cant get thru someone help me please. it just seems to be in a loop
    asheville n.c.
    618
    or someone let marshall brown under sa200 thread know ive got 1 4 sale and im right in n.c. thread is in motor sports loop
    Central illinois
    98
    Default motersports
    hay beamwalker i have tryed & tryed two weeks ago and cant get thru.
    did you ever work in southern ILL. in the coal mines. i worked with a guy that called himsalf beamwalker. this was back in the late 80s & earley 90s.
    miller bobcat 250
    wc 115a
    spoolmatic 30a
    centery 250 mic
    2 lincoln 225 stick
    a 1954 hobart portable welder w/ willies jeep engine
    did you regester over there seperetly?? for some reason the 2 are not conected.
    i posted a link to this thread over there for ya. good luck.
    Aug 2002
    Appleton, WI
    207
    Default Motorsports Board
    Yes, the two boards are actually on separate administration systems, so you would need to register separately. If you have done that and still can't get through, please let me know and I can help you.
    Just a note, when you register, you'll get an e-mail with a link to click to confirm your registration on the board. This e-mail sometimes gets caught in spam filters, so if you do register on the other board and don't see an e-mail pretty quickly, check your spam/junk folder for that e-mail to complete the registration process.
    I administer both message boards, so if you have trouble with either one, feel free to contact me.
    Thanks!
    I am registered on both boards and I had the same problem a few weeks ago. I could not get into either board by using my normal route which is just selecting it in my favorites. I had to go to the miller home page and then click on the projects icon, then I could click on the message boards. I never figured it out, it just fixed itself after about two weeks. It was annoying to say the least.
    Now that I just posted that, I find out that I have been demoted. I had a lot more than 1 post before.
    Aug 2002
    Appleton, WI
    207
    Default Troll
    Hello there,
    That's certainly strange as we have no way (and no reason) to "demote" anyone in the number of posts they have?
    Because I can't "demote" anyone, I also can't "promote" anyone either...
    Could it be you hadn't posted on the projects side previously?
    The number of posts will be separate for each board.
    yep they are seperate i got over 5,000 posts on the motor sports board and only 200 ish here.
    you might check and see if you are registerd more than one time. on another board i foud out i was regesterd as fun4now and fun4now. so when i logged in one day my post count was way down couldnt figure it out turns out i was regested 2 times and for some strang reason my brouser signed me in under the other name and i wasent aware it even existed. so if its possible you might have regesterd 2 times you might want to check, look at the members list and see if there are 2 of you.
    befor you ask no you dont get 2 pay checks.
