Page 6 of 7 FirstFirst 1234567 LastLast
Results 51 to 60 of 63
Thread: Dune Buggy
  1. #51
    S.W. Pennsylvania
    2,250
    Looking better all the time !!!
    How far is it from the top of the rear coil to the brace that comes down from the roll bar ? That looks like it could be a possible weak spot.
    My sincere thanks , Pete.
    Pureox OA
    Westinghouse 300 amp AC stick
    Miller Syncrowave 250
    Hexacon 250 watt solder iron
  2. #52
    the bracket that the coilover bolts to is 1 1/2" center to center
    AIM: Zachary188
  3. #53
    S.W. Pennsylvania
    2,250
    Quote Originally Posted by burninbriar
    I'm talking about the tubular frame work. It looks like the tube could bend where the coil connects to it upon heavy impact in rough use. Maybe a brace from the coil bracket up to the tubeing that runs to the roll bar would make it a little stiffer ??
    Pureox OA
  4. #54
    ohh i see what you are saying, its about a foot from the downbar. I dont foresee it having any problems but ill take a closer look at it tomorrow, thanks for looking out
    AIM: Zachary188
  5. #55
    well today i mocked up the interior again, mounted the radiator, and started figuring out brackets for the r&p/spindles.
    its officially crunch time. one week and one day to get it road worthy
    AIM: Zachary188
  6. #56
    got the tie rods done today, and the fuel cell straps done. Tomorrow ill start welding up all the loose ends and hopefully jake will pick up the crank/block tomorrow from the machine shop, drop off the transmission, drop off the driveshaft, and we'll hopefully start painting by friday
    let me know what you think
    AIM: Zachary188
  7. #57
    Got the chassis painted, bedlinered the interior, painted most all of the suspension parts, and assembled the motor. more pics tomorrow
    AIM: Zachary188
  8. #58
    S.W. Pennsylvania
    2,250
    What a differance a little paint makes. I want to see some pics of that rascal airborn and kicking up some dirt !!!
    Pureox OA
  9. #59
    haha yea believe me, seeing that burnt brown rust color was getting old. And im sure a few burnout/jumping videos will be in the mix soon
    Today I assembled the 4 link, rear coilovers, front coilovers, 90% of the steering, master cylinder/brake pedal, control arms, fuel cell, and did some more work on the motor.
    AIM: Zachary188
  10. #60
    Today i got the rest of the motor/trans assembled and installed
    AIM: Zachary188
