Page 4 of 7 FirstFirst 1234567 LastLast
Results 31 to 40 of 63
Thread: Dune Buggy
  1. #31
    removable trans mount finished, boxed the front bottom of the console, rear of the console, did alot of welding underneath, and got the block/trans mocked up again
    AIM: Zachary188
  2. #32
    got the shifter, head unit, and speakers mounted
    comments/suggestions welcome
    AIM: Zachary188
  3. #33
    S.W. Pennsylvania
    2,250
    Its really comming along nice. On post 31 in the third pic down it looks like youre useing the sheet metal for a note pad. Is that youre things to do list ?
    My sincere thanks , Pete.
    Pureox OA
    Westinghouse 300 amp AC stick
    Miller Syncrowave 250
    Hexacon 250 watt solder iron
  4. #34
    Thanks burninbriar
    yea that was just a quick list i made. mostly fab stuff left to do
    AIM: Zachary188
  5. #35
    Feb 2006
    Oviedo Fl.
    26
    Default Look'in good
    Man thats look'in good now lets go have some fun.
    "Molten Metal Fusion Technician"
  6. #36
    BEFORE PAINT:
    a-arm tabs
    Tie Rods
    spindle bracket
    weld chassis
    crossmembers
    weld rearend
    Grind center console
    fuel cell
    Fuel cell mount
    radiator mount
    Gas pedal
    Cooling tubes
    Gussets
    Tie Rods
    weld/grind floor
    coilovers
    coilover mounts
    finish a arms
    fuse block mount
    brake lines
    seatbelts
    4th steering bearing
    alternator bracket
    diff cover
    reciever hitch
    D-Shackle hooks
    Tow bar
    Do brake job front/rear
    driveshaft
    AFTER PAINT:
    Wire
    run brake lines
    fuel line
    assemble suspension
    shifter/kickdown cable
    plumb radiator
    plumb tranny cooler
    rebuild dist.
    rebuild motor
    rebuild transmission
    throttle cable
    speedometer cable
    and some other stuff..
    got a late start today so all the link tabs are tacked in place just need to finish the oscillating washers *cam washers* to adjust the caster/camber not that it really matters much lol.
    AIM: Zachary188
  7. #37
    got a few more things done
    and btw i didnt want to weld to the bolts but was forced into it lol.
    AIM: Zachary188
  8. #38
    S.W. Pennsylvania
    2,250
    Quote Originally Posted by Camaro Zach
    Looks good ! One thing I don't understand, and I dont mean to put youre freind down in any way, but why does he have you do things you dont want to do when its obvious that you are the one who knows what he is doing.
    Pureox OA
  9. #39
    well really i just dont want to argue with him because he is a know it all. in the whole i have told him how everything is going to go and thats it but on the smaller things i dont really mind since he likes to learn things the hard way. BTW after removing the transmission one time he decided it was time to change the crossmember
    AIM: Zachary188
  10. #40
    started on the fuel cell today and ran into some problems on my test welds. Pic 405 shows the porosity and dullness. I dont know what it is but i tried both 2% thoriated, and ceriated tungstens (3/32) Aluminum is .090 3003 and 3/32 4043 filler i believe. Also what do you guys usually use to prep the al. prior to welding?
    Thanks for the help,
    Zach
    AIM: Zachary188
