Thanks jarto
And thanks miller for the tape measure!
Results 21 to 30 of 63
Thread: Dune Buggy
03-05-2006, 05:15 PM #21
AIM: Zachary188
03-05-2006, 10:45 PM #22
Looking Good , Zach
Looks good Zach , In the earlier photos i didnt see any welding stands do you have them and just didn't use them or do you need to build some ? I build trailers and speciality equipment , and have a set of plans for welding stands if you would like to look at them . Dan
03-06-2006, 10:39 PM #23
Thanks Dan,
i dont have any welding stands but i'd be happy to see your plans
ThanksAIM: Zachary188
03-15-2006, 11:48 PM #24
got a little bit more done today, let me know what you think
AIM: Zachary188
03-17-2006, 07:34 PM #25
started on the tach/speedo cluster today
AIM: Zachary188
03-17-2006, 07:47 PM #26
- Sep 2005
- S.W. Pennsylvania
- 2,249
This project is really looking great. I was wondering what kind of brake you are useing to form youre sheet metal ? Particularly the peice over the guages with the radius bends. I see a line down the center of it . Is it in 2 peices or is that a pencil line ? ( I'm refering to the last picture)
My sincere thanks , Pete.
Pureox OA
Westinghouse 300 amp AC stick
Miller Syncrowave 250
Hexacon 250 watt solder iron
03-17-2006, 08:37 PM #27
Thanks burninbriar,
for the tight radius bends i used my generic sheetmetal brake i think its called a "bendito" or something cheap like that. For the gauge cluster i actually just clamped a piece of 4" pipe to the sheetmetal and rolled it over the pipe. The line was a sharpie so i could keep the centerline the seperation of the 2 bends consinstant.AIM: Zachary188
03-17-2006, 08:46 PM #28
- Sep 2005
- S.W. Pennsylvania
- 2,249
That guage cluster looks really nice for doing it by hand. Do you arm wrestle ???
Pureox OA
03-22-2006, 06:55 PM #29
got the R&P mounted, steering joints and tubes all welded in, and got the gauges tacked in place.
AIM: Zachary188
03-25-2006, 08:11 PM #30
today i built a brake pedal, mounted it, mounted the master cylinder, almost finished the battery bracket, and almost finished with the firewall. Let me know what you think
AIM: Zachary188
