Results 11 to 16 of 16
Thread: Railing help!
    now in Orlando!!!!
    557
    Here is better link for King, they are in Baltimore,Dallas and I think LA. I have used them many times and feel they offer a great resource, Hope this helps, Paul
    kingmetals.com
    More Spark Today Please
    Oahu, Hawaii
    2,469
    I think he mentioned using square tubing. We've done it at school using 1/2" solid square. Put one end in a vice with 1" pipe over it to keep it straight while twisting (other end was a "Key" we made using extra scrap 1/2" bar that fit snugly around what we were twisting...If you guys know how to twist manually similar to that, PLEASE let me know, that tubing is a lot cheaper!!
    bert
    I'm not late...
    I'm just on Hawaiian Time
    8
    what kind of steele you use cold roll or hot?
    Littlestown Pa.
    30
    Quote Originally Posted by migwelder05 View Post
    dont have a machean do it old school all you need is a A/O torch, a vice and some friends. heat it up to cherry red weld a pice on the top first then stick it in the vice and twist it that what ide do
    thts how ive always done it
    Lake of the Ozarks MO
    3,446
    Use hot roled 1/2" solid...it really ain't hard to twist...put one end in a vice and use a big crescent wrench on the other end and mark it with soapstone and give it two turns (as a starting point) Take it out and look at it and adjust from there....it doesn't get much more crude or simpler than that!!
    Then if you like what you see then weld two old 1/2" sockets together and use a big ratchet on one end and a third socket welded to the bench or whatever also using the drive end to put the picket in...still crude but not quite as Neanderthal.
    Ocean City, Maryland
    951
    You need to twist it cold. if you heat it up it will twist wherever the heat is. If done cold it will twist evenly between the 2 places its held. Made some cool stuff this way. And not to hard to twist
    Scott
    HMW [Heavy Metal welding]
