question on welding galvanized
  • question on welding galvanized
    i need to build some freezer racks out of galvanized. what would be the best prosses to weld it with? mig or stick. should i use 6011 or 6013 or some fluxcore. they will be 1 /8 thick angle and 1/4 round stock. Any suggestions would be greatly appreciated. also all u guys and girls do a great job and are very helpful keep up the good work. also want to give a shout out to those who live in nc.
    Either process is Ok -- but for the thickness you describe, I'd use the stick machine (DC+). Not trying to lecture you or anything, but I'm assuming you are very familiar with the hazards of welding galvanized material. Proper ventilation, a dedicated supplied air source and joint prep are just the starting points.
    I know some professional welders who won't touch galvanized. You could get killed welding this stuff if you don't take the proper precautions.
      Either process is fine. Just make sure you only weld for a few minutes then take a few minute breather in a fresh air enviroment. Also drink lots of milk.
        Since I don't know whether you're in the welding profession I can only comment.
        "taking a breather and drinking lots of milk" will definitely get you very sick. It doesn't take too much exposure to zinc fumes to get poisoned (welder's fever). The proper procedure is to use a proper respirator or better yet, a dedicated air source. Since you can absorb the zinc not only through your lungs but also through any exposed tissue -- such as your eyes.
        Some of the more senior guys on this forum will know more about the OSHA requirements and where to find the proper procedures for welding zinc coated metals.
        Be careful!!
          Hi dredgewelder, I spent the majority of my career in marine construction. Mostly bridges and docks. Iíve done lots of docks with galvanized piling and beams. Iíve also been galvanized poisoned 12 different times. Trust me itís not fun .
          If I had a lot of welding to do I would use Hobartís 21-B Fabshield. Iíve run literally tons of this, it performs better than NR-211, or 212 on galvanized material . If using SMAW, 6010 or 6011 will work.
          Now what works best for me is to set up a fan real close to your work, and blow the fumes away form you. And of course work outside!
            When observing at work I seen a guy using stick for welding galvanized. Im sure flux cor will work just as well.
            Thanks for reading I hope my post helped
            Ryan
              Galvanized in a freezer....
              Freezer racks are a big pain the butt. Galvanized is a big pain, too.
              I've had the best luck on galvanized running 6011 DCEP. When we fab galvanized we try every combination and that one give us the least splatter and the least cleaning.
              But, and I do mean but, GMAW may be the best choice. I just don't have one to try.
              VOILA! A reason to buy a new machine! COOL!
              Triggerman
              Ammonia refrigeration tech
              Trailblazer 302 (yes, it's new)
              Millermatic 180 w/Autoset
              CST-250
              HF-15 High frequency
              XR15 w/Push-Pull Gun
              Victor O/A, DeWalt, North mask
              "A professional knows what to do. A craftsman knows why."
                Be careful!!
                I'm not a professional, but my instructor taught me the milk thing. He's spent 28 years in the Navy as welder, welding on a lot of galvanized on the ships.
                  Grind as much of the galvinizing off of the material if possible, and use a resporator with the proper cartrages... There are cold galvanizing sprays that can be used to cover up the grinded / welded area after the job is complete. Be careful, only a single strong inhalation of the fumes can make you sick. Milk seems to be a very old method of protection from zinc(but still viable), but honestly, you will still be welding in a cloud of poisonous fumes. Cadmium poisoning is similar to zinc poisoning in my experience, I first encountered it when welding toggle clamps onto a frame jig using TIG back in 94.
                  Jonny
                  Dynasty 300DX
                  Esab PCM 1000
                    i don't see why you want to use galvanized in the first place. personally, i would use stainless with 308 blue max rod.
                      Answer#1: $
                      Answer#2: $
                      And, finally, answer#3: $
                      Triggerman
                      CST-250
