Sheet metal brake
  • Sheet metal brake
    As the song goes; "A long long time ago........", I built a sheet metal brake. It works fine, but I can't bend four corners of a box. I want to start over or modify, changing to high clearance and removable fingers or some other way i can fold a box with 10" high sides from 16 gauge aluminum. I now bend two sides, and add two ends. While I love welding time, distortion is a concern.
    Has anybody got a good design?
    Dynasty 280DX
    Bobcat 250
    MM252
    Spool gun
    Twentieth Century 295
    Twentieth Century 295 AC
    Marquette spot welder
    Smith torches
    found this one, haven't made it yet. Will do 16 gauge full width (approx. 24 inches)
    http://www.woodworkforums.com/f65/ma...rs-home-45792/
      Mine (homemade) does 7' 3". At first I thought your link wouldn't help me, then I thought; I have a massive press, most boxes and pans are rectangles, why not a set of dies for the press to do the shorter sides?
      Thanks, you planted the seed for thought.
      Dynasty 280DX
      Bobcat 250
      MM252
      Spool gun
      Smith torches
        good luck. post some pics when you're done, if you can.
          Willie, I have the HF 20 ton press with an air/hydraulic jack, been considering this
          http://www.swagoffroad.com/20-TON-Fi...-Kit_p_86.html
          Might be some ideas to "borrow" there... Steve
            Try this thread where I did something similar
            http://mapletrader.com/community/sho...nute-Syrup-Pan
