Snow Plow Bracket Repair
  • Snow Plow Bracket Repair
    Here in Michigan we have had a winter with so much snow that it has been very hard on the snow plowing equipment. Below is a welding project I just did to fix the bracket that mounts under the truck and supports the snow plow, for one of my customers.
    Miller Thunderbolt
    Smith Oxyacetylene Torch
    Miller Dynasty 200DX
    Lincoln SP-250 MIG Welder
    16" DuAll Saw
    15" Drill Press
    20 Ton Arbor Press
    Bridgeport
    Miller Spectrum 375 Plasma Torch
    Here are the rest of the pictures...
    Miller Thunderbolt
    16" DuAll Saw
    15" Drill Press
    20 Ton Arbor Press
    Bridgeport
      I can relate to that fix, I blasted a curb with my plow and have to pull it off to see if I need to do any repairs
        Did you replace it with the same thickness or one size bigger? Looks like a fine job. Always nice to see someone cut it out & do it right vs. just globbing it back together.
        MM250
        RCCS-14
          Nice job.
            I believe that I replaced it with the size that it was when it was new.
            The plate had been thinned down due to rusting.
            Miller Thunderbolt
            16" DuAll Saw
            15" Drill Press
            20 Ton Arbor Press
            Bridgeport
              MMW, I was thinking the same thing when I looked at the first pick, and when I looks at the last one I said great, He got rid of the fatigued metal.
              Just welding it back is cool to get you back plowing to finish but is just going to break within the next couple of storms.
              Good Job.
                very nice job , that will get them going again!
                I have a welding addiction
                ...the only stupid question is the one you didn't ask
