Steel Spheres
  • Steel Spheres
    Anyone seen one of these? I got the idea from this website: http://blog.custommade.com/house/mel...que-fire-pits/
    They are making some killer fire pits. But I have never seen a premade sphere. Any ideas?
    MillerMatic 251
    Maxstar 150 STH
    Cutmaster 42
    Victor Journeyman OA
    My buddy has 2 of them about 32-34 inches in dia. They were used as channel markers in a big lake close by...Bob
    Bob Wright
      Wow!
      That second picture is beautiful and tragic at the same time.
        And btw, I would love to have one if there is a source near eastern NM or west TX...
          Here you go http://www.blueoceantackle.com/spher...teel_buoys.htm ...Bob
          Bob Wright
            Firing it up would be too depressing.
            Miller 211 AutoSet
            Miller Dynasty 200 DX
            Thermal Dynamics Cutmaster 42
            "The Sleep of Reason Produces Monsters"
            Francisco Goya
              Thanks Bob! Now to find one for cheap.
              MillerMatic 251
              Maxstar 150 STH
              Cutmaster 42
                elvis,
                Here are some companies who manufacture pressure vessel ends.
                http://www.cmforming.com/tankheads-and-accessories.htm
                http://bakertankhead.com/products/tank-heads.htm
                Of course they are probably more $ than the channel marker buoys Bob found.
                The type you want are the hemispherical ones.
                Non-ASME ones are cheaper.
                There is probably a manufacturer near you.
                Get 2 and make your own sphere.
                King Metals sells steel hemispheres up to 12" in diameter.
                They also have a 12" stainless sphere for around $300.
                A restaurant near me has an outdoor seating area with 4 commercially made wood burning fire pits.
                I looked closer and they were simply 48" steel hemispheres with a drain hole in the bottom.
                More fun to make your own which is why we're all here.
                good luck,
                  Burnt
                  Thanks! The more options the better. I live in the desert so no buoy stores right here... I'll look into some tank ends. I have looked at those for other projects but they can be expensive.
                  MillerMatic 251
                  Maxstar 150 STH
                  Cutmaster 42
                    Originally posted by elvis View Post
                    Burnt
                    I just watched Hangover the first movie and that wrecking yard outside Vegas where they took the Benz has 3 of those big channel markers in the background...Bob
                    Bob Wright
                      Nice call. At least there is a big lake by Vegas. I'm in southern Arizona. Lots of rocks here.
                      MillerMatic 251
                      Maxstar 150 STH
                      Cutmaster 42
                        Hey Elvis, I have some tank heads from some 1000 gallon propane tanks I cut apart. I could probably be talked into parting with a set. Do you still have my number?
                          Should have it in a pm. I'll check tomorrow when I'm on a computer. Down in Tucson now and thinking about swinging through Prescott on the way to San Diego at the end of the month. Could make a stop then... I'll look for your number tomorrow and give you a call if I find it.
                          MillerMatic 251
                          Maxstar 150 STH
                          Cutmaster 42
                            Also look at round propane tanks. They are usually in the 60 gallon range for size.
