1200# implement and 1/2"x3" flat bar
  • 1200# implement and 1/2"x3" flat bar
    I have an implement for a farm tractor that weighs 1200#s. I'm building a three point hitch mount out of A36 flat bar that is 1/2x3". The flat bar has 1-1/8" holes drilled in it 1-1/2" from the back and 1-1/2" from the top and bottom for an outside edge distance if 15/16" all the way around. The implement is 7' long overall with the 1/2" flat bar sticking 6" past unit. My question is: will the (4) pieces of 1/2" flat bar with the 1-1/8" holes be strong enough to pull and LIFT the implement?
    What kind of an implement? That will make a huge difference on weather or not it will be strong enough to pull it.
      Pictures would help
        Picture would definitely help. Are you making the 3 point hitch like what's on a rear blade ? What type of implement ? Here's a search I did that may help.
        http://www.bing.com/images/search?q=...itch&FORM=IGRE
        http://www.bing.com/images/search?q=...ents&FORM=IGRE
          Landplane grader
          The implement is a landplane grader. Ill attach some pics! The unit is 7'x7'. I plan on using (6)1/2x3"x12" pieces of bar across the front tube and attaching to the two center supports that are 32" apart.Name:  7dafdee682c0e37ad43f5e0765b2861c.jpg
Size:  51.1 KBName:  cedbb86a2981add1e4217df1dca94987.jpg
            How big a tractor do you plan to use? I would keep the Cat II attachment as short as possible, not much more clearance than 1/2" behind the 3 pt. hitch arms in the pocket or if you need the extension for some reason maybe exterior gussets as far out as you can get without interfering with the pins. I don't know how heavy the tube is but the 1/2" x 12" reinforcement is a good idea I think. What are you using for the 3rd link?---Meltedmetal
              Tubing size
              The center link will be mounted on the same 4"x4"x5/16" tubing 20" up in between the two lower links. I will be using the same flat bar. The flat bar is cut in 12" sticks but at least 6" will be welded to the cross tube and overlap the two supports in the middle. Tractor is a 58 horse ih784. Keep in mind this is where the hitch will attach to the impement: A36 flat bar that is 1/2x3". The flat bar has 1-1/8" holes drilled in it 1-1/2" from the back and 1-1/2" from the top and bottom for an outside edge distance if 15/16" all the way around. these (4) pieces are where the lower arms will slide into an attach. overall lenght may be 12 inches but only 4-6 sticking past the implement itself.
                It sounds like to are gonna make something like what's on these ,
                http://www.bing.com/images/search?q=...electedIndex=0
                  You are correct BD1. I have the impelement built and it weighs a total of 1200#. I'm just not sure if what I have made, the (4) pieces of 1/2" flat bar with the 1-1/8" holes be strong enough to pull and LIFT the implement? The two grader blades I have will be cutting 1" below the skids at a width of 7'. I guess I'll put them on there and try it. If it doesnt work I'll cut them off and buy some 5/8"x4" flat and go again.
                  Thanks guy for your time!
                  John
                    I would expect that with 70 horsepower you will not have too much of a problem. The next question will be "Is your tractor big enough?" Looks good so far.---Meltedmetal
                      Should be no problem. I would definitely run steel from the top link connection point down diagonally to help transfer some of the stress when lifting.You will not have a problem lifting it for sure. If you do, GO GREEN, John Deere Green that is. Just had to say, my 2440 ,750 , plus lawn tractor. I do have a '' M''
                      and Super H .
                        Crops are green tractors are red
                        and Super H .
                        Thanks BD1! I will run the diagonal out of a piece of 3/8x4"angle. I was concerened about the 15/16" edge distance. But I'm thinking it won't be a problem. As for a big enough tractor. 58 hp at the draw bar and it has 250# wheel weights on the side. It should put me ove 6000 for the overall weight. There is a formula to calculate HP needed for a given implement size,weight,width. It's gonna be close depending on how deep I cut with the grader.
                          It looks like you have plenty of room, if you are worried just go to a bigger/thicker flatbar. Additional cost is marginal. Also easy enough to double up the metal where the lower hitch pins bolt to, just cut a square, drill a hole in the center, bolt the hitch pins in, and weld the sides.
                          One thing I will stress, if you are using bolted in lower hitch pins (vs a clevis type connection), make sure you get them tight!!! Over the years, I see more failures due to loose hitch pins wobbling holes out than from inadequate metal.
                            You should be good to go. Just look at the manufactured ones for more ideas. Pictures make it so much clearer . This internet stuff is amazing, saves weeks of traveling to go look at them .
                              Clevis connection
                              It will be a clevis type connection. I do like the idea of doubling up the material sort of a big square washer welded to the existing material. I used the 1/2" cuz that's what I had. I don't do near enough fabrication to justify another 21' stick in the garage. But four pieces of 1/2"x3"x12" flat bar welded100% to the unit on both sides at a length of 8" with a 4" overhang for hitch hook up should be ample with the use of those big ass washers.
