Portable Horse Feeders
  • Portable Horse Feeders
    The little woman is taking an adult education welding class. She needed a project for class so I whipped this out and helped her lay out 3 more. When the instructor saw this he asked if I would start helping him with the class.
    Not sure why only one photo came up but here is the other view.
      Looks good. Is that solid round bar or hollow tubing
        Solid round
          Give it a good prime and paint .to protect it from the elements.
          Looks real good .
          Miller Bobcat 225NT onan
          Millermatic 211
          Spoolmate 100
          Miller 130xp
          2. 4-1/2" grinders
          1. 9" grinder
          14" Makita chop saw
          1/2" Aircat impact gun 900#
            That will hold up well. Much better then the store bought for sure.
            Smart getting the little woman educated in a welding course. Now you can buy HER a new machine for CHRISTMAS !!!!!
              I should do the same . I need a tig welder
              Millermatic 211
              Spoolmate 100
              Miller 130xp
              2. 4-1/2" grinders
              1. 9" grinder
              14" Makita chop saw
                Thank you all for the kind words. As far as getting her a welder... Well... That's exactly what we want her to think...
                  An if your nice to her, she MIGHT let you try it out. Don't forget to get her, her own hood too.
                  The only thing I think it might need is to add some short legs to the corners to get the plate steel off the ground for air circulation so it doesn't rust out from underneath where you can't normally see it. That's where the moisture will accumulate and attack the steel, and you won't know it until it(rust) shows up on the top side.
                  You say this is a "Portable Horse Feeder", HMMM, I thought ALLL horses were portable.
                    She is pretty spoiled because she already has a brand new hood and another on the way for Christmas. We will be adding some pieces to the back of the feeder so they will hang on the pipe fence. The corral they will be used at isn't used year round so the feeders will spend most of the time in the barn and only be on the fence when the horses are there. We are researching the spray on bedliner option but want to make sure it is safe for the horses.
                      Dang smart phones... Showes the last post didn't go but it's on there now.
                        Send dimensions,,,,.
