indcution heaters for loosing nuts what is your ex opinion
  • indcution heaters for loosing nuts what is your ex opinion
    this was asked on another automotive forum but no respond
    See few of these around, these induction heating nut loosing gadgets. Anyone used them professionally in their shop? worth to get ? these seems to be home use ones not sure how good they are. Don't want to store oxy-acetylene at home and the oxygen-mapp gas ones are never strong enough. tried welding on nuts to broken bolt trick 50% works and pain when doing it under car.
    OTC 6650
    Mini-Ductor
    BoltBusters
    Fluxeon
    I think miller have one for pipe heating for 25K which is out of range for avg Joes
    I just use my O/A torch for this purpose. I don't mind storing the O/A tanks at home. The torch is handy for cutting steel and heating it for bending it too. If you are doing much metal working at all, then an O/A rig is almost indispensable.
    What's wrong with storing O/A tanks at home?
      access is the main thing when working under car without lift. I can wield O/A torch novice. but hard to do that under a car trying to access something that is in tight spot (safely). Acetylene explodes as far as what I learn when in school over 15PSI. Actually still remembers some young chap blown up in his car when he was going to work and had a small O/A tank inside.
      But seen these induction things in youtube, that these things heat / some even melt metal. just not sure how durable they are when it is made for home use. Still not cheap price avg about $600, that is why asking around if some one had experiences to share on this matter. Last thing I wanted is to spend that kind of $ end up with a piece of paper weight after first use.
        That's what regulators are for. Just keep the pressure set below 15 PSI and you will be OK.
        Ditch the car and get you a pick up truck. Or at least you could get an external cargo carrier that fits on a receiver hitch to carry it outside of the car. I have 2 pick ups, so transporting acetylene is not a problem for me.
        I have not seen or used one of these induction heaters you mention, so cannot comment on how good they are.
          I have a mini ducktor. Expensive. ($200 from snapon but needinv repair) But I like to use it for removing bearings, drawing straw color. It is quick and fire free.
            I hope miller continues with their inducted heat programs. A time will come when tossing a wire around some thing is more natural than grabbing the flame wrench.
              they have the ProHeat it's a little out of range for my price as home DIYer and way over kill for what I needed it for... Maybe they made a lower end attachment to my Dynasty 200DX would be nice... send me a testing sample if you do every made and market such product
