I love doing buckets
  • I love doing buckets
    Here is a Cat 330 48" bucket. The operator smashed the bottom in while driving posts in the ground. Gave them a price last fall on a new floor, wear bars & also sides because they were thin. Owner said screw it, let them use it as is.
    Fast forward to two weeks ago & now they need it fixed as it is worn through in the corners & splitting about 12" on each side. The mechanic has welded a couple patches here & there over the last several months to keep it going. The kicker is they want it done as cheap as possible. They have a sheet of 1/2" plate laying out back for the floor. Says just pc. it in instead of having it bumped or rolled. Use HRS bars instead of AR wear bar.
    First two pics are when I first saw it. Last pic is yesterday.
Size:  58.2 KBName:  7d41f82e71825ed631bb421c7059a406.jpg
Size:  38.9 KBName:  d08f61d0e9529b7744656c8b0c7adb14.jpg
    MM250
    RCCS-14
    I cut out the floor & used three pcs. to make it. Sunk it up in so I had plenty to weld to. Added 3/4" x 4" HRS flat bar to bottom. Coming out better than I thought it would although kinda flat on the bottom but that's what I was told to do. Just have to finish welding the inside now.
    Pic 1 is of the finished bottom, pic 2 is of the floor where it meets the edge. I tried to get a good pic of the weld but didn't come out good. Pic 3 is the inside ready for welding. Gouged out the seams.
Size:  44.1 KBName:  5f9332a4664c2f52c7d8995d9640c21f.jpg
Size:  41.2 KBName:  d94da1c3aadf16e9cb9cd52bc387c1b3.jpg
    MM250
    RCCS-14
      Well now the operator can drive his Pontiac Sunfire into the pavement and that bucket will be fine.
        1/2" seems kinda light for 48" bucket.I know you said the owner made the decision but I think 3/4" would have been a wiser choice.
        BB402D
        TB300D
        DIMENSION652
        MM250X
        MAXSTAR140
        S-32 FEEDER W/1260 IRONMATE FC/GUN
        HT/PWR-MAX1250 PLASMA
          Wow, 3/4"? The original floor was about 5/16" or 3/8". I have never seen a bucket this size with a 1/2" or 3/4" floor. The wear bars I used were 3/4" though which is standard around here except these are HRS not AR as per owner.
          28' of 3/4" x 4" hot rolled flat bar = $192 vs. 28' of 3/4" x 4" ar = about $700
          MM250
          RCCS-14
            And the hr will last about a 1/4 of what the ar will.You get what you pay for.Now the time to remove all the worn hr off and redo you could have bought ar the first time.It all comes down to how cheap the guy payn the bill is.
            BB402D
            TB300D
            DIMENSION652
            MM250X
            MAXSTAR140
              I wouldnt put any less than 10mm in their usually around 8mm new
              I usually put 10mm×50mm mild wear bars if trying to keep cost
              But ideally you need to put hardox as wear strips i usually use hx450
              If you ain't burnin' you ain't learnin'
                I should of mentioned that I always recommend using wear bar on buckets. In this case it was specified not to so as to keep the cost as low as possible. On buckets this size I always use 3/4" bar either 3" or 4" wide depending on how they sit on the radius. When these wear thin I will just put a second layer over the top.
                MM250
                RCCS-14
                  I will say mate 3/4 is a bit overkill.
                  For this size id use 15mm hardox at the max
                  Also welding little circles on the wear bars will stop them wearing even more do this on
                  The cutting edge as well between the adapters with hard facing rods
                  You can also weld sections of 15mm x 70mm between the adapters on the back of the cutting edge to save it wearing out.
                  Also you can either weld plates on top of the adapters or run hard facing weld over them.
                    MMW,
                    Very nice work. What does a job such as that cost?
                    Thanks,
                    Nick
                      MMW, I totally understand, You did what the customer asked of you, The only thing I usually do different is to run my wear bars past the outside edge of the bucket to protect the corners and always make sure the leading edge of the bucket is wider than the back to prevent it from sticking, I'm sure you know that but wanted to remind others reading this post.
                      Nice job.
                      The customer is always right and this way you will get to rebuild the bucket a little sooner than normal, Its a win win for you.
                        How about this one
                        This was one of the hurry up and get it done as cheap as possible. Is a 54".
                        JIM
                        Millermatic 350P Aluma Pro
                        Maxstar 150 STL
                        Trailblazer 302
                        Suitecase 12RC
                        Extreme 12VS
                        Extreme 8VS
                        Spoolmatic 30A
                        Miller HF251D-1
                        Passport Plus
                        Spoolmate 100
                        Hypertherm Powermax 45 and 85
                        Dake 75 ton H-Frame Press
                        JD Squared Model 32 Bender
                        Miller Digital Elite
                          While were at it.
                          This was another one. Was much smaller, but still.....
                          JIM
                          Maxstar 150 STL
                          Trailblazer 302
                          Suitecase 12RC
                          Extreme 12VS
                          Extreme 8VS
                          Spoolmatic 30A
                          Miller HF251D-1
                          Passport Plus
                          Spoolmate 100
                            What kind of material will it be digging in? I ask cause I always put the wear bars on going side to side instead of front to back.
                            Looks good but wow were they beat up.
                            MM250
                            RCCS-14
                              looks great to me.
