250 gallon reverse smoker
  • 250 gallon reverse smoker
    Well I always wanted one so here we go.......
    I assume you are putting water in with the hose. See that foam in the Tank7 photo? That is from the water reacting with the mercaptan (the odiferant, aka stinky stuff, used in propane). From the MSDS for mercaptan:
    PHYSICAL HAZARDS: Extremely flammable liquid and vapor. Vapor may cause flash fire. Contact with water or moist air may generate flammable and/or toxic gases.
    Be careful.
    Tim
    Many cordless tools...........
    2 cordless hammers
    2 cordless punches
    1 cordless chisel
    2 cordless screwdrivers, 1 + and 1 -
    and a cordless adjustable wrench that also doubles as a hammer.....
      Originally posted by pin2hot View Post
      I assume you are putting water in with the hose. See that foam in the Tank7 photo? That is from the water reacting with the mercaptan (the odiferant, aka stinky stuff, used in propane). From the MSDS for mercaptan: Be careful.
      note taken......
        Looking good!
        Glad things worked out. What I shared earlier was 'the voice of experience.' I guess I was lucky.
        Tim
        2 cordless hammers
        2 cordless punches
        1 cordless chisel
