Bucket repair
  • Bucket repair
    This is from a PC200. It's not the angle of the pic. They actually pulled the center of the cutting edge down & cracked it on the outside of the two center shanks as well as split the seam where the edge meets the floor. Need to straighten as best as possible & weld it back up. I gouged out the shank cracks from both sides till they met & put the machine weight on the two center shanks. It didn't move. So I kept gouging toward the seam until it did. Got the left crack lined up & welded. Tomorrow I'll work on the right crack & once that is done I'll try to push the whole edge center up & weld the seam. Then I'll go to the bottom & gouge/reweld the seam as it is cracking also.Name:  abbeb77ca16bb2a8fa306abd1a0781ac.jpg
Size:  41.8 KBName:  35ba91a0ee80ebba7274635c6d1a54b7.jpg
Size:  31.8 KBName:  cdca7790fb86a19a6ee35ba67aab087c.jpg
    Bucket repair
    That looks like a pain in the bucket. lol. I spent the dat cutting apart a plow frame for a tractor snow plow rig and welding it back together
      MMW, You forgot to give us a pick of your welding rig.
      I love welding on buckets like that, I just had a 5 yd excavator bucket in my shop, I had to relocate some ears and then have it line bored.
      4 of us could stand in the bucket.
      Thanks for the pic.
        Here are some more pics.Name:  4e19c0f1824e8467bec32cf87e6a842f.jpg
Size:  41.3 KBName:  ed8f2f07752713679d6edc43433b880c.jpg
Size:  45.5 KBName:  8bb53245fa6265b26513f0097f9f4d5c.jpg
        First pic was the only spot I had to heat as the web was sharply bent down about 3/4" in this spot. Not perfect but acceptable. You can see the steel block under it so all the weight is on this one spot. Second pic is the left side crack welded up. Third pic is using the excavators weight to try & straighten pic #1. You can see the front of the tracks off the ground.
Size:  41.6 KBName:  266d85bbd1094ffeed98c3e7978bd368.jpg
Size:  32.1 KBName:  2d59a70e649a134ae74fed318c060885.jpg
          First pic is finished. Again not perfect as it still has a slight smile to it. I could of spent a lot more time getting it perfect but at some point you need to weigh the amount of labor vs. the results. To get it to this point I felt was a reasonable amount of time but realized to get it the rest of the way could have taken to much time. The machine is mainly used for loading trucks at a supply place so it won't matter if it's not perfectly flat. The last two pics are of the outside & inside all welded up.
            MMW, Looks like a good fix, I hope you preheated prior to welding.
            Looks like the frost did a number on bending and tearing the mole board ( At least thats what we call it )
            The one thing about welding on equipment buckets, Is that you find out if you did it right within an hour usually.
            Howacome I did'nt see a rig pic.
              Portable, I posted rig pics in other thread. http://www.millerwelds.com/resources...Details/page26
                Nice job on the bucket repair.
                  Wow MMW, You went back along way for those pics, Sorry for forgetting.
                    You didn't forget. I just posted them today. I never figured ouy how to post pics here until recently. Since I have a whole library full from the last few years I can post them now & then, along with new stuff.
                    I thought there was another thread of rig pics but that was the only large one I found. I thought it funny that when I opened it you were one of the last to post on it.
                    I just wanted to let some of the newbies see the thread so I didn't start a new one.
                      With as much work as you did on the bucket why not replace the edge? Once they crack they keep cracking....it's weird that the lip is worn so bad but the shanks and teeth look new. Did they put new shanks on a worn out edge? If it's just for loading rocks why bother straightening? Welds and all look good, just seems like a really big bandaid when a transplant was in order....
                        turbo38t wrote
                        "With as much work as you did on the bucket why not replace the edge?"
                        Because this was a cheaper option. It's not just the labor replacing the edge with new. You have the cost of a new edge. The cost of new shanks or the labor to remove all the old ones & weld them on the new edge & don't forget that the corner shanks are part of the bucket side also.
                        Like I said I straightened it as much as I could reasonably. It's not perfect because to get it the rest of the way would of taken a long time. Customer was happy.
                        As far as a big band aid? I wish every customer would say I want it like new. Replace the edge, floor, shanks, wear bar, etc. but this isn't 10 years ago when money was flowing. I just did a 42" bucket last week. 1/4" ms plate liner only. The floor is paper thin the first layer of wear bar was worn out & a second layer was put over the top of that some time ago. Would of been a big job to replace it all not to mention that wear bar is now $20 a foot for 3/4 x 4".
                          I gotcha. You are correct as to doing what the customer wants. The thing I see is that if you do replace the edge and shanks then u have a bucket good for a couple years of digging. I'm betting you will be doing this same repair a month or three down the road or the lip will break in half and NEED to be replaced. Sometimes my boss wants the wear bars replaced but the floor is so damaged and he still says "ahhh.....just take it outside, beat it out with the stick of an excavator, force the new wear bars on and weld it up .....we don't wanna spend a lot of time on this thing"....well...truth be told, in this situation it DEFINITELY would have been quicker for me to cut the floor and wear bars out in one piece, burn a new floor on the plasma table OR with a torch, make a couple bends on the press and weld all new in. I wasted so much time cutting old bars off, grinding everything, trying to straighten a floor that was beat in 3" and then the amount of time to weld it up with all the monster gaps....and now I know the floor was paper thin and will wear out in a month or less. I guess it's what the boss wants LOL.....
                            Agreed, if the customer does whatever he did last time with that bucket, it's gonna break again. But you also have to keep in mind, do whatever the customer wants. I hear more and more, thanks to California Air Resources Board, "Do the minimum necessary, I gotta scrap it next year anyway, just patch it so it lasts another year." Doesn't make sense doing a major rebuild on something that will be legislated obsolete in a few months. . . .
