20t Press
  • 20t Press
    I am going to buy materials soon for a few projects I NEED to get done. I have to build a welding table, tube bender and 20t press. Anyways, off to the press first!
    So far I am thining about 6"x6.7# channel for the vertical, top and floor beams. I have some 2x2x3/16" angle for the legs. Planning on 1/2" plate for the pressure plate and bracing in key areas. I was thinking 3/4" cold rolled steel for the adjustable pins. But I wanted to go with a 1" cold rolled driver off the jack. I just wanted a little more steel around the adjustment holes on the vertical beams.
    I am planning on using a HF 20t A/O bottle jack. I can run 150psi into the jack and a second regulator for the plasma and other tools that won't run at such a high pressure. Planning to MIG everything together but I have a boatload of 1/8" and 5/32" 7018 sitting next to the rod oven.
    So what say you? I looked at the crappy HF presses today and realized that the incremental cost to have a quality press with an air actuated jack is not very large.
    My store bought 20t press uses 1" pins for table adjustment.
      I use 1" pins also...Bob
      http://www.millerwelds.com/resources...986#post297986
        X3 on the 1" pins
          Wouldn't it make building everything else easier if you built the table first?
            These are just my thoughts. The only bad thing about using channel for the sides is drilling the holes nice and straight thru both webs. You will almost have to drill all of them from the flat side. That means laying out 4 sets of holes. I layed mine out with a 1/8"x3" flatbar layed out with the spacing then drilled them 5/32 and used a transfer punch to layout the posts. Keep the edge of the flatbar even with whatever end and punch away. Thats why i used angle and an ironworker and still have the flatbar pattern for the next one...Bob
              Quote -- Planning on 1/2" plate for the pressure plate and bracing in key areas
              If by pressure plate your refering to the top plate that the jack pushes against I would use 1". My press has a 3/4" plate that is bent from use.
              Depending how good you are with the mig & what size it is, it will be your call. If it was me I would not trust it with a small mig. These things get overstressed constantly & it would not be pretty to have a weld let go when maxxed out.
                Alright, so 1" pins it is. I was looking at a few presses and I liked the ones that had dual pins on each side.
                It would make it much easier to have the table first, and that will probably happen first. I'm figuring out what to buy next week while I'm in the big city. Steel is WAY cheaper where I currently am located as opposed to where I live. Which is good because I'll end up with at least a half sheet of 1/4" plate that will become a tube bender after a little time on a cnc plasma table, a half sheet of 1/2" plate, plus the materials for a shop press as well as a combo cart for the stick machine and plasma and all my welding gadgets (c-clamps, grinders, consumables, rod oven, 230 and 115v power distribution, etc.)
                I have debated using 2x3x3/8" angle for the vertical posts with the 3" sides touching and welded together. Or perhaps 3x3x3/8" angle for the main frame. I like that it would give me more material on the sides of the adjustment pins. I was also thinking of a staggered pressure plate with 2 layers of 1/2". With the largest contacting the top of the press frame and the smaller one below and finally with jack contacting the lower plate. I will need some arbor plates, however, and those should be 1" thick so maybe I will just buy some 1".
                My mig power source is capable of 300 amps, give or take. I'm pretty decent with a mig so I would be comfortable welding it together with er70s6. Also, looking at your press frame bob I like how much adjustment there is. I think I'll talk to a local shop and see what it would cost to get 60 1" holes punched through 3/8" material.
                Also, I mis-typed on my first post. I was actually thinking about 6"x8.2# or 6"x10.5# channel.
                  Ok, I have decided to make the vertical beams out of 2x3x3/8" angle with the 3" sides touching and welded together. I'll gusset or box the channel in a few spots to keep the beams from deflecting. I am pretty much making 6" channel. I need to get this sketched up on the computer so I can show you what I'm thinking.
                    I know what you are thinking. It would be stronger with the 2" sides touching. Just my thoughts...Bob
                      Sounds good bob. I think it will be stronger than regular c-channel because the "ears" will have more material to them. The angle will have the thick corners to make it stronger there, just like the channel would. 10# 6" channel is only 2" wide on the ears and when you take into account the web thickness you are putting a 1" hole into something that only has a drillable width of aproximately 1.7". .7/2 = .35" on each side of the hole. Then add a downward force of 20 tons and add a whole bunch of holes. Seems like you are asking .35" of steel to do a lot of work. At least once you get down a few table levels and your stretching the very thin material that is around each adjustment hole above the table.
                      It would be neat to learn how to load calc this type of thing.
                        If you want 6" between the bed plates just space the angles apart with some flatbar welded on the outside. You can make it wider than the 4"...Bob
                          Here is what I was thinking. Sorry that the picture is a little fuzzy. Took it with my phone. On the top view there is a seam between the pieces of the angle. The scale for the top view is 1 square = 1 inch. This is primitive but I think it conveys the point better than my words do.
                          The front view the beam would be 3" wide, due to the width of the angle. The table would have to span a total width of 4" front to back. Does that make sense? I like the adjustment hole design that you have on your press and I would do something similar to that.
                          Also, I was looking at an inside width of somewhere around 40". Maybe 42". I want to be able to build a brake for this press and work with 36" long material without any issues.
                            20T isn't going to go far on thickness and that wide of width. You would be looking at sheetmetal prob 16 ga at that. Just my thoughts...Bob
                              How much would I need for say, 3/16? I'm looking at offroad related bracketry. Most everything I make is need is out of 3/16" thick stuff.
