My First Welder and First Project
  • My First Welder and First Project
    I just got my Miller 150S this week. Since I needed a welding table I thought it would be a good first project. It’s based on the welding table project on the Lincoln Electric site. The hardest part was welding on the coupling nuts for the casters even after sanding off the zinc plating. Once I got an ugly but serviceable weld I found I had penetrated a bit too much and had to spend about an hour running a tap through and then testing with a bolt over and over before the bolt went all the way through.
    Joe
    PS: The welding table is supporting a dish of ice cream that my wifeName:  002a1eaaf7c3eb9aebde1b18563329d5.jpg
Size:  27.8 KBName:  db7b63a4649a5769fa1fdd3fb25b63da.jpg
Size:  26.0 KB insisted be in the picture.
    Thats the way
    You learn heaps from just setting up your work area.
    Keep up the good work
    Ji
    Grip it and Rip it
      Looks good. Did you use flux core wire on that?
      Lincoln Vantage 400
      Trailblazer® 302 Air Pak™
      Miller Dynasty® 350
      Millermatic 350P Aluminum
      Millermatic® 252
      Syncrowave 351
      Lincoln LN-25 Pro
      Multimatic™ 200
      XR-Aluma Pro Gun
      Diversion™ 180
      Spectrum® 625 X-TREME™
      Victor Oxy/Acetylene Set
        Thanks, I used 6011 stick. I'm pleased with the result even though for a few bucks more I could've bought a Miller folding table. But, as Jigantor pointed out, I did learn a lot. Some of it, real basic, like getting familiar with a chop saw.
          Not too "familiar" I hope...?
          Just For Home Projects.
            Looks good! How thick is the top? I tend to go heavy on the top as I am usually beating on something there. Also helps with keeping it flat over time.
            Campbell Hausfeld 110V MIG
            Jo Ann Fabrics Hot Glue Gun
              Thanks. The top is 3/16" the bottom is 1/8" or I believe 10 g. The horizontal angles are 3/4." I would've preferred 1," but the angles and plate I bought was dictated by what was available at the building supply store. The top is too bouncy for pounding. Perhaps I'll stiffen it by welding an X brace underneath it at some later time. At the time I didn't want the table to be heavy because I wasn't sure I would be able to handle it. Nevertheless, I can appreciate why some use 3/4" plate on top.
              Btw, the only thing I did differently from what was on the web site was to shear off a half inch off the width and depth of the bottom plate so that the legs would be square. If you follow the directions on the Lincoln site the legs will be splayed out a bit. The aesthetics of that bothered me.
                When you spring for the bucks to buy a nice new welder and the steel to make a welding table it is appropriate to place a bowl of ice cream on top of it, for the inauguration picture.
                I had a couple things that could help you in the future.
                1. If you want to take zinc plating off coupler nuts or any other hardware for that matter put it in Hydrochloric acid (Muriatic acid) for about 15 minutes and then rinse well in water. The acid will make a lot of bubbles and remove the plating. You can get the acid in the paint department of home depot. It is used for cleaning concrete. Picture 1 shows a coupler bubbling away in the acid. Picture 2 shows a coupler before and one after the zinc plating was removed.
                2. If you are going to weld in a coupler pick the largest hex size you can find. It will give you a better chance of not having the weld penetrate through to the threads. Picture 3 shows two 3/8”couplers that have different hex sizes. Use the larger one.
                3. Coat a bolt or threaded rod with anti-seize and screw it into the thread of the coupler before welding. This will act as a heat sink and help to keep the weld from penetrating into the threads of the coupler.
                4. Use a 6013 rod instead of a 6011 rod. The 6013 rod is designed for mild penetration while the 6011 is for deep penetration. This will help keep the weld from penetrating into the threads. Picture 4 shows the larger coupler welded to angle iron like yours with a 6013 rod.
                5. I’m not sure if this is the case but I will often offset the top plate ¼” from the outside edge so that I can use a fillet weld to attach the plate to the frame as shown in picture 5.
                6. You might enjoy attached link. It talks about the 6013 rod and the 6011 rod. It is specifically for A/C but it would also apply to your DC.
                http://www.weldingtipsandtricks.com/...ap-joints.html
                Good luck with your welding projects.
                Don
                Miller Thunderbolt
                Smith Oxyacetylene Torch
                Miller Dynasty 200DX
                Lincoln SP-250 MIG Welder
                16" DuAll Saw
                15" Drill Press
                20 Ton Arbor Press
                Bridgeport
                Miller Spectrum 375 Plasma Torch
                  Don
                  Thank you so much for those excellent tips and posting the pix! I certainly want to use threaded stem casters over plate casters in the future. This will make it much easier.
                  And I'll be ordering some 6013. We used in the first couple of classes. It's very easy to produce a nice looking weld with it. To think, I thought it was just a beginner's rod!
                    Don 52 mentioned good points. You should try some 3/32'' 7018 along with the
                    6013. I think you will really like these rods.
                    What's your location ?
                    Looking forward you next project photos. As your skill level increases, the wife may just add whip cream to the ice cream.
