Some welding projects....looking for opinions part 2 !!!
  • Some welding projects....looking for opinions part 2 !!!
    The following are several pics of some welding projects I recently completed. I am largely self taught with the most time on MIG welding. TIG and Stick have only been recently.
    These were all done with metal I scrounged or had on hand.
    This is a welding table.......was all MIG welded except for several small welds that I TIG welded after I ran out of gas for the MIG.
    The last is a vice stand I made for use outside. Two of my three welding tables have a receiver style for the vice and I built this to take advantage of this. All MIG welded.
    The table looks fine but the vice stand I have a proplem with. If the vice is extended with weight in it, it will be subject to tipping. Also I would have put the vice bar in line with one of the legs which I think should be longer.
    Nick
    Miller 252 Mig
    Miller Cricket XL
    Millermatic 150 Mig
    Miller Syncrowave 200 Tig
    2-O/A outfits
    Jet Lathe and Mill
    Jet 7x12 horz/vert band saw
    DeWalt Multi Cutter metal saw
    Century 50 Amp Plasma Cutter
    Propane Forge
    60" X 60" router/plasma table
      The vice was mounted wrong for the pic. Switching it 180 degrees does put the vice over a leg. I didn't build it for anything real heavy. I also don't plan on extending out it out either. Pretty much built it for a second pair of hands to weld or grind on !
        Hi, RAH.
        I looked at both posts.
        I think you did a good job welding/painting, etc.
        Everybody finishes a project and thinks "now, how could I improve that?", so there will always be opinions on how to do better.
        Both of these look like fun projects and I'm sure you learned from each.
        Keep posting and keep welding!
        Burt
        _______________________
        Miller 211AS
        Miller 375
        Miller Syncrowave 250
        Miller Thunderbolt XL
        http://www.10FtDrillBit.com
          Good job, you just joined the club of the guys that made something to be improved, in fact this happens to me on most of my projects...
          the best prospects always show-up after the wedding
