Quick warning for visitors to your shop
  • Quick warning for visitors to your shop
    I wanted to be able to prevent my wife from getting welding flashes when she comes into the garage (My shop) without knocking. I couldn't train her to knock so I made this.
    First I put a "Man's" bathroom sign.
    Then i took some plexiglass rod that I had from something else.
    (I imagine a clear stick for adjusting window blinds would work well too.)
    I cut the rod .5" longer than the thickness of my door and rounded over one end.
    I tried to heat it to make the ends clear but it did not work (still working on that solution).
    The I drilled 2 holes where the eyes would be on the "Man" sign and jammed the rod in with the flush side going into the house and the .5" extra going into the shop.
    If the lights are on in your shop the eyes will glow. if you are grinding near the door the eyes will glow orange (or whatever color the sparks are) and if you are welding and the light from the arc is getting on the door the eyes will glow very bright.
    Hopefully the pictures fill in the spaces in my description.
    Any ideas or comments are welcome.
    Nice idea!
    At home:
    Dynasty 200 DX
    Millermatic 211 Auto-set
    Spoolmate 100
    At work:
    2-Syncrowave 250
    2-maxstar 150
    millermatic 250X
    Dynasty 200 DX
      To make the ends of the plastic rod "clear," polish them with some very fine polishing compound.
        +1
        Headlight restore if you got it.
        Kemppi Pro Evolution 4200
        Kemppi 530 wire feed with MXE panel
        Kemppi ProCool ( coming soon)
        Cigweld TransMig 210se
        Cigweld TransTig 200 AC/DC
        Hypertherm PowerMax45
        CutSkill O/A setup
        Speedglas 9000x adflow
        Speedglas 9100xx
          Try dipping them in acetone. Thats how they clear screwdriver handles after machining in factories
          Nick
          Miller 252 Mig
          Miller Cricket XL
          Millermatic 150 Mig
          Miller Syncrowave 200 Tig
          2-O/A outfits
          Jet Lathe and Mill
          Jet 7x12 horz/vert band saw
          DeWalt Multi Cutter metal saw
          Century 50 Amp Plasma Cutter
          Propane Forge
          60" X 60" router/plasma table
            That's cool!
              inside latch works for me
