Setting up my place
  • Setting up my place
    I'm setting a place (about 20ft x 30ft). I'm gonna have two tables, one movable and the other fixed, also have plans for a portable work station I found (was made from wood over a steel frame).
    Movable table (1/2" top 24" by 48")
    Fixed table (1/4" top 29" by 50")
    Work Station (29" by 25")
    Maybe will do smething like this:
    What kind of fabbing will you be doing?...Bob
      Will start with 4-5 of this:
      Or this one
        Or this one
        Cool. Need some of these???...Bob
          In the picture labled fixed table I see a huge fire hazard. Lots of stuff on the shelves that are most likely flammable. Make sure you know where your sparks from grinding, cutting, etc. are going. Get a few extinguishers.
          Good luck with the first "job".
            Thanks for the comment but the table was outside the room when I took that picture. The room I'm going to use is empty right now because need to set up some pegboard to hang some c-clamp, etc. Thanks again
            P.D. Will get some Fire Extinguisher also
              It looks like a basement. Do you have ventilation in the room to the outside? A must when welding a lot. You'll also need make up air. Concrete walls & floor are good.
                Yep, I'm working on that also
                  Looks like it will be a nice place to work.
                    Looks great man the only thong thay giys me is you.meed braces on the bottom.of the fixed table or over time due to heat and weight it will warp. I really like it though I wish I had a vise and bench grinder on a floating table.
                      Good luck ! Check some of the table work bench threads for more ideas to help make it more efficient. Receiver tube is a must on table along with a place to hang grinders, clamps, hammers, squares, etc. It will be nice with a dedicated work room. look for a four wheel cart for material moving or storage. WHEELS is the answer on concrete.Have fun and keep us posted !
                        Did some work on my fixed table this weekend. When I took the last picture it wasn't finished. Hopefully I'll finish it this coming week.
                          Nice, that frame work for shelf will work out well. What distance above floor are you going to set it ? I would set it for whatever you want to store underneath. Never have enough storage.
                            Thanks, the legs are 33" so I'm thinking to weld the self about 16" from the floor
                              That looks **** near identical to mine I did the same thing. mine is 3/4 plate and abut 8 inches off the bottom is 1/2 plate I store everything from pipe wrenches to porta powers on it. It is about 13 years old and just a tough as the day we made it. It"ll last forever.
