campfire bbq ?'s
  • campfire bbq ?'s
    what kind of steel should i use to make the grill out of? im guessing its gota be stainless steel since im going to be cooking food on it. but i think ive also heard a thing called food grade stainless? any input would help thanks.
    Steel
    I used a-36 hot rolled, 3/16" steel. Then 1/2" hot rolled for the Grate. It is rusty but it is 4 years old already. Similar to the Camp ground grills seen at Northern tools. I tiged all of mine for practice.
      campfire bbq ?'s
      I would use 304 stainless steel, lots more $$$ than carbon steel but will last a long time and will clean easy. Watch your heat, both cooking and welding.
      Kevin
        well i was googling and found you can buy pre made replacement grills for not too much money i might go that route since its probably cheaper then buying ss. thanks.
