Frame plating
  • PA Weldor
    started a topic Frame plating
    Frame plating
    I'm plating the frame of a F250 Ford Super Duty and will be installing a 'Sneeker' repo wheel lift on Monday. I normally remove all items from the frame rails and cut 1/4" plate for this job. Customer provided 3/8" plate, and I had to cut 5 pieces for each side. The 3/8" is too thick and would have required I move the spring pads on the axles. Considerable rust had to be dealt with at this used to be (and still is) a plow truck. Former owner carried salt in bed. I plasma cut all the plates and welded them to each section by MIG. I profiled the plates to match the profile on the spring hanger brackets. I recently rebuilt the Sneeker so he should have a good to go repo rig by next week.
ID:	530524Click image for larger version
ID:	530525Click image for larger version
ID:	530526Click image for larger version
ID:	530527Click image for larger version
  • PA Weldor
    Originally posted by cayager View Post
    hey paweldor are you paul the gas pipe welder?
    Sorry, I'm not that guy. Never did any pipeline welding. Have done lots of industrial stuff. On my rig (before I semi-retired) I had a Lincoln SA200, Miller AEAD200LE, Miller spool gun, and Miller Hi-Freq. Don't do any portable work anymore, just in shop.
  • cayager
    pa weldor
  • cayager
    Originally posted by 1930case View Post
    Thousands of wheel lifts, wrecker masts, winches, accessories and beds have been mounted and their parent vehicles modified successfully without engineering approvals. It's not an aircraft or a pressure vessel.
    Light-duty wheel lifts aren't particularly hard on a truck. That install has Timbren load boosters which take a lot of load off the spring perches.
    (The other classic mod is overload leaf springs which stay in light contact with modified contact points (usually a piece of square tubing tacked to the tab to bridge the gap) so that any squat immediately engages the overload. That can be used with or without Timbrens.)
    Looks good.
    i would have to agree. i worked in a welding shop/ truck equipment shop for years fabricating all sorts of equipment,dump trucks, roll offs, shortening and lenghtening trucks. never had anything engineered. never heard anything from dot or any others.
  • PA Weldor
    Originally posted by Daniel View Post
    Sorry, I didn't know repo business wasn't considered commercial. Around here this would be fresh meat for the DOT.
    That's ok, Daniel. Although these rigs don't fall under commercial guidelines (most of them) they should. This particular rig is only rated for 3500 lbs, but they haul much heavier...
  • Daniel
  • PA Weldor
    It's not an aircraft or pressure vessel but still carry around a car or a pick up truck on public road. The DOT here are pretty picky on frame mods of commercial vehicule.
    Different area different rules.
    The vehicle is NOT a commercial vehicle. It's not used for commercial towing, only repo work. The capacity is only 3500 lbs. On most 'commercial trucks' the frames are heat treated and I won't weld on them This is a whole different ball game.
  • Daniel
  • 1930case
    Looks good.
  • Daniel
    Sometimes the customer is not always right and need to be put i the right direction.
    I didn't know frame mod on a towing didn't need to be engineered.
    We cant even make a lifting eye without being engineered at our work place.
    I guess public road safety is not a concern in your area.
  • PA Weldor
    Originally posted by Sberry View Post
    I might have tossed th 3/8 to the side and used 1/4
    Customer supplied the 3/8 and wanted it installed...
  • Sberry
  • PA Weldor
    Looks like your weak spot is going to be right at the spring pad, which is where you want it to be the stronger. Where are you going to get this inspected before commercial use?
    Actually the spring pad areas are generally pretty strong. We've never had one fail in this area. The spring mounts on the frame are pretty stout stuff, and act as the frame were plated in this area. If the plate customer provided was 1/4" then I would have removed all objects on the frame rail and installed the plate, then reinstalled the items. I've done repairs on other's work, and you wouldn't believe the lousy plating installation. A tack here and there.
    Doesn't have to be inspected. Even if it did, it will pass.
  • kevin
    nice work, i got sprayed by a skunk in harrisburg while hitch,n back to n.h. years ago, i will never forget harrisburgh pa
  • Daniel
