Grease and Grime?
  • Grease and Grime?
    Whats the best way to clean the dirt and grime off of metal before going to paint?
    I use oileater-spray it on full strength, then wipe it off with a rag in a diluted solution. Costco sells oileater and I've gotten it at Checker auto. cat
      I try to get the worst of it with a wire brush, wipe it down with a clean rag, then go over it with a rag dampened with mineral spirits, making sure its wet enough you dont just smear the dirt around.
        Agree,
        If you are dealing with a small amount of material, the above options are great. However, we generally clean 2 to 400 pounds of material at a time and use a pressure washer and and bio-degradable degreaser (orange peal oil) and then dry with a propane heat blower and of course towels.
        Good luck,
        TacMig
          simple green, and water mixure in a weed sprayer then wipe down with sponge, then pressure wash
            Great replies! Thank you!
