32 ft gooseneck car hauler
  • 32 ft gooseneck car hauler
    I just received the steel for the 32ft gooseneck triple axle trailer I am going to build and I have a few questions. I have repaired many trailers, and built a couple small ones, but never built a 32 footer, so is there a formula for where to place the axles exactly? I figure with three axles there should be about 16 or so ft to the beginning of the first tire, and about 8ft or so behind the last tire. But Im not sure. Also, I planned to use (4) 32ft pieces of 6"x 10.5# channel (.314 thick web) spaced 14" apart and 1/8 diamond plate runners. Does that sound strong enough? The cars weigh 3200 lbs each.
    My gooseneck tongue will be 10" x 15 lb(Ithink) wide flange I beams.
    Any help would be greatly appreciated,
    Thanks,
    Christian
    Voigt Precision Welding, Inc.
    Miller Dynasty 200 DX, Miller Syncrowave 250, MillerMatic 252, Hypertherm Powermax 45, Auto Arc Trailpower 8000,272+187 lb Peter Wright anvil, 120 lb Fisher-norris, and more! Buffalo drill press, Grizzly Horiz. Bandsaw, Edwards shear, Barth Shear, bantam mechanical ironworker, Hopkins fly press, Doall Bandsaw, brown and sharpe surface grinder.
    2007 Silverado 2500HD (tow vehicle)
    2000 Camaro SS (Race car)
    sigpic
    I used to place mine 1' back of center. I will give you a good tip. Weld your spring hangers on some 1/2"x3" flat bar and assemble your axles and tires as a rolling assembely then you can roll the whole unit under your trailer frame and move them around to what looks right. Then just weld the flatbar to the beam...Bob
    Bob Wright
      Originally posted by Iron Head
      3-axles leads me to believe you’re going for a 21,000-lb trailer?
      You may want to reconsider this!
      The major trailer manufactures use 12-inch x 19-pound S-shapes for their gooseneck in a 14,000-pound trailer. You maybe pushing you luck with 10-inch WF, unless you’re going with something like 10 X 22 where the flange is 5 3/4-inches wide. A 10 X 15-pound WF only has a 4-inch wide flange. You might want to consult an engineer!
      Im using 3 5200# axles and I am going for 12,000-13,000 gvwr. The flange looks to be 4 inch, might be a tick over if im not mistaken. I only went with this since I copied the basic design from something I saw, that used 8" channel. I figure the trailer with cars should weigh between 10,500 and 11,000 pounds probably 10,500. I may try to check with an engineer if you guys think it wont be enough for a 12,000-13,000 gvwr trailer.
      And thanks for the tip bob never thought of that.
      sigpic
        Any other suggestions?
        Just saw a 10000 gvwr gooseneck with 8"x 11.5 lb gooseneck....
        sigpic
          Im going with the down slope..
          Here are some pics of the first day...
          sigpic
            sigpic
              One tip and i know you prob don't work by your car but, Don't let the grinding sparks hit your car glass because they don't come off they just burn in and rust in place....Bob
              Bob Wright
                Found that one out when I used to work in a body shop, when I was 16, never made that costly mistake again.... That's not even my camaro, it's my fathers, swept out the garage so thats why its there
                sigpic
                  I read somewhere one time that the placement of single axles is 60% of the trailer in front of the axle and 40% behind it. On a double axle trailer, you can use the halfway point between the two axles, a triple, use the middle axle. I hope this helps.
                  Ken
                  Hobart Handler 187
                  Dewalt Chop Saw
                  4" Air Grinder
                  Die Grinder
                  Rigid Drill Press
                  Kellogg 10hp Air Compressor
                  2009 FXDC
                    Day 1 of the build....
                    sigpic
                      sigpic
                        Looooooooking good so far!
                        What wire are you running?
                        .035 Lincoln I think L-56 not sure.
                        sigpic
                          What kind of paint should I use that would be most cost effective, longest lasting, etc. I have many sprayguns, so application wont be a problem.
                          Thanks guys.
                          sigpic
                            Back when i painted those 500 trailers it was Dupont Centari Acrlyic enamel because we got it cheap being OEM. Today i would go to a farm store and buy their imp & tractor paint and some bare metal primer. The paint my local store has is made from Valspar paint company the same company that makes House Of Color paint. It has held up well on my wrought iron stuff in the yard...Bob
                            Bob Wright
                              LOOOOOKING GOOOOD!!! nice work so far ceep it up. those are sone mighty fine looking cars you got in he back ground! Do I see TWO camaros! OOOOWEEE!!!
                              Miller Digital Elite inferno
                              Miller MP-10 passive helmet
                              Hobart Stickmate 250/160 ac/dc
