Chimney Top
  • Chimney Top
    Sorry, I haven't gotten by here much lately. It's been a very busy year, so I'm not complaining, especially in this economy.
    Last spring the top blew off the fireplace chimney. Too much heat & smoke turned it brittle & it broke like dried leaves. They have to be special ordered around here, they're expensive & we've gone through 2 in 11 years. So, I took a couple hours & made one out of .080 aluminum sign cut-offs.
    At a sign shop, you use what you have. Made a template out of scrap vinyl.
    Wheeled a little pitch in the top & bottom pieces for water runoff.
    I don't have tipping dies for the bead roller, so I picked something close & went with it
    Used the shrinker / stretcher & a hammer to get a 90.
    Test fit the bottom half on the stainless inner liner.
    I tried everything I could think of to make the louvered sides, but nothing turned out right (wasted a good part of the afternoon figuring that out). So, as an alternative, I stomped out a handful of aluminum stripes on the shear, used the bench vise & a crescent wrench as a jig & bent all the stripes into louver pieces & then clamped spot welded them to the top 1 by 1. Then did the same with the bottom
    It actually went together fairly quick once I had a system down. Welded some mounting tabs on the bottom & got it installed in the dark. Installed some rain gutter screen on the bottom to keep birds out of the liner vent. I have to do a little re-sealing on the chimney itself, but it started to rain just as I was putting the last screws in.
    Cross another Honey -Do off the list in my quest to get back on the "Z". Been some chilli mornings lately & NO fireplace.
    It's nothing fancy, but it should be functional & hopefully last a little longer than the thin gauge store bought units. Now that it's on the roof, nobody will notice except maybe me & Santa Claus.
      Looks really nice. Gonna outlast those bought ones too.
      Professional firefighter (retired). Amateur everything else I try to do...
      Oh yeah: GO BIG RED!
        Rust won't be a problem any more, just watch out that the heat doesn't get so hot that it melts the louvers. Otherwise it's another trip back topside for a rework. Looks like you have plenty of firewood stocked up already.
          Thanks everybody. This was one of those "just get the thing done" type job. I didn't spend much time making it pretty, but hopefully it will do the job for a few years.
