Repair of Cracked Chute on Branch Chipper
  • Repair of Cracked Chute on Branch Chipper
    My most recent project was to repair a wood chipper. The chipper had two chutes; one for leaves and finger sized twigs and the other for branches. The problem was the branch chute. When people feed branches in the chute and the branches get hung up, they tend to apply a back and forth motion to the branch to get it to feed into the chute of the chipper. This in turn applies a moment to the branch chute, which caused the recent failure. In this case the failure was cracking located on the top and both sides of chute at the flange where the chute attaches to the chipper base. As expected the cracks were in the heat affected zone next to the welds. I would have liked to add angle iron to the sides of the chute to beef it up, but I didn’t have enough time because my customer needed it for a church clean up. The original chute lasted about 10 years and I would expect that the repair will last as long even without the side angle iron, but I do expect it to eventually fail. In picture 4 you can see the penetration on the back side of the weld.
    Miller Thunderbolt
    Smith Oxyacetylene Torch
    Miller Dynasty 200DX
    Lincoln SP-250 MIG Welder
    Lincoln LE 31 MP
    Lincoln 210 MP
    16" DuAll Saw
    15" Drill Press
    20 Ton Arbor Press
    Bridgeport
    Looks good here. They should have reinforced those areas before it left the factory. Should last your lifetime!
      Picture 4 is a back penetration. This was done with mig right?
      Nice repair
        All of the welds were done with TIG. I only welded the outside of the chute. Picture 4 is what penetrated thru the crack from the TIG weld on the outside.
        Miller Thunderbolt
        Lincoln LE 31 MP
        Lincoln 210 MP
        16" DuAll Saw
        15" Drill Press
        20 Ton Arbor Press
        Bridgeport
          Looks like the original weld was cold. Looks like there might have been a notch at the edge of the bead, and that's what started the crack.
          Dynasty200DX w/coolmate1
          MM210
          MM Vintage
          Lincoln AC225
          Victor O/A, Smith AW1A
          Cutmaster 81
          IR 2475N7.5FP
          Evolution Rage3
          Jancy USA101
          9" South Bend
          AEAD-200LE
            Attached is a close up picture taken before welding of one portion of the crack.
            This picture corresponds to the right side of the reinforcement tab on the top of the chute, which is shown after welding in picture 2.
            It does look like a cold lap on the left side.
            Picture 8 is another close up of the crack on the top.
            What do you think?
            Miller Thunderbolt
            Lincoln LE 31 MP
            Lincoln 210 MP
            16" DuAll Saw
            15" Drill Press
            20 Ton Arbor Press
            Bridgeport
              It wasn't nuclear grade or meant to last forever, no one wants to pay for it, Crap happens, likely the repair will outlast the rest of the machine.
                Now you're going to have up close pictures of your crack all over the internet
                MM210
                MM Vintage
                Lincoln AC225
                Cutmaster 81
                IR 2475N7.5FP
                Evolution Rage3
                Jancy USA101
                9" South Bend
                AEAD-200LE
                  I learned a little bit and enjoyed your comments.
                  Thanks,
                  Don
                  Miller Thunderbolt
                  Lincoln LE 31 MP
                  Lincoln 210 MP
                  16" DuAll Saw
                  15" Drill Press
                  20 Ton Arbor Press
                  Bridgeport
