Electric Question
  • Electric Question
    All I have right now is an electric drier outlet thatís not the same plug configuration needed for the MM180. So I bought a 6í 10gauge 30 amp drier cord for a pig tail, connected the power outlet (wall receptacle) to it that the welding shop told me to use, My question is: is this all I need, to then plug in the 25í 8/3 extension cord for my MM180 ? The MM180 cord is 12/3
    Will this be safe to use..
    Fab Tech
    Fab Tech
    Well.....
    The short answer to your question is: yes, it is safe.
    The long answer: The friction connectors are susceptible to loosening and making a poor contact. Inspect your connectors regularly (under load, if possible) for signs of heat. Other than that, go on ahead.
    Good luck.
    Triggerman
    Ammonia refrigeration tech
    Trailblazer 302 (yes, it's new)
    Millermatic 180 w/Autoset
    CST-250
    HF-15 High frequency
    XR15 w/Push-Pull Gun
    Victor O/A, DeWalt, North mask
    "A professional knows what to do. A craftsman knows why."
      My first career was as an industrial and commercial electrician. If the dryer receptical was all I had; that's exactly how I would do it. How ever, if access to the panel wasn't too much hassle, I would make a dedicated welder outlet. Perhaps a local electrician would trade out the work for some welding. Just my 2c.
      Some people are like slinkies. They're not good for anything, but you can't help but smile when our see one falling down the stairs.
        Thanks guys for your feed back, in the morning Iíll cut up some 1X1 tubing and fire up this pup, do a few tack welds and see how this works out. For my first welding project, it will be a welding cart, :-) Oh ya Iíll have photos too LOL.
        Fab Tech
        Fab Tech
