Help
  • Help
    I have just recently started building tube frames for my 1/10th scale remote control trucks out of 1/4 inch brake line. I use a torch with mapp gas to braze the joints. Right now I'm useing Harris Saftey Silver 45% silver brazing alloy, it works great. The only problem is that it cost about $27 a troy ounce. I was wondering is anyone would know of something else I could use with mapp gas to braze my joints thats cheaper.
    I have a small propane torch i bought more than 30 years ago that will braze. Sure wish they still have them now i would point you to one...Bob
      Harris sil-phos 15% copper brazing alloy. With the same flux you are using for the silver solder, it brazes steel just fine. It's no where near as pretty as the 45% silver, though.
        You can just use brass brazing rod, a lot less money than silver.
