Caterpillar trackframe project
  • Caterpillar trackframe project
    Project I worked on today. Thought you guys could be interested seeing a few pics.
Name:	work 003_1_2_1_1_4_1_1_1_1.JPG
ID:	529937Click image for larger version
Name:	work 005_1_1_1.jpg
    A few more. I have some modification and processor head attachment I did on a 324 loader if you guys are interested to see I'll post them later.
    Cheers
Name:	work 018_1_1.jpg
ID:	511285Click image for larger version
Name:	work 009_1_1.jpg
ID:	511286Click image for larger version
Name:	work 011_1_1_1_8_1_1_1_1_1_3_1_1_4_1.JPG
      what was the problem you were fixin on the track frame? picsof your other work would be great. Tom
        It's an add on for reinforcement. It's a new equipment and this was customer request. I have to put top cylinder guards and blade stop as well.
          Looks great ,one question what is the idea of your beads running off a inch or so on each piece????
            It's feathering your end welds, it srpeads the stress point. You have to do that for diamond shape fishplate as well. If you have to weld a block in the middle of a boom side, you'd have to weld only on the 2 opposite sides and feather in the block and weld the side and feather out. I'ts a good habit to take.
            If you dont do this, most likely a crack will start from any corner of any welds on the face of a plate.
              Was wondering the same thing but too scared to ask
              Nice job - looks good!
                not quite following on the feathering, got a pic or drawing? pigpen
                  Actually ,if you look at the 3rd picture in the second post it makes it look like a caterpillar!
                  Miller Syncrowave 200
                  Homemade Water Cooler
                  130XP MIG
                  Spectrum 375
                  60 year old Logan Lathe
                  Select Machine and Tool Mill
                    That's hilarious, didn't notice.Good one
                      Is the second pic the finished weld? If so, doesnt the weld section need to be relative to material thickness?
                      It seems thick for a single pass or no bevel. It also cold be my eyes.
                      Kemppi Pro Evolution 4200
                      Kemppi 530 wire feed with MXE panel
                      Kemppi ProCool ( coming soon)
                      Cigweld TransMig 210se
                      Cigweld TransTig 200 AC/DC
                      Hypertherm PowerMax45
                      CutSkill O/A setup
                      Speedglas 9000x adflow
                      Speedglas 9100xx
                        It's about a 3/8 legs for the bead and the gusset is 3/4 t-400. It's to help stabilise the front idlers.
                        I finishing installing the blade stops 3"X6"x10" with a radius on the same machine. And it only calls for 3/8" legs on the bead and 1.5 " run off ""feather to ctick that big block to the side of the blade mount frame.
                        I'll post pictures of it.
                          I've heard that a fillet on both sides only needs to total 75% of the thinner base metal thickness.
                          3/4'' x 75% = .28
                          2
                          Thats why 1/4, 5/16, and 3/8 fillet sizes are the most popular. It takes a big chunk of steel to require more than a 3/8 fillet on both sides. Especially if you figure in the effective throat.
                          '08 F-350
                          Vantage 400
                          SA-250
                          SA-200
                          Invertec V350Pro
                          Invertec V205T-AC/DC
                          Miller 12VS suitcase
                          Miller spectrum 2050
                          Pipe beveler's
                          Track torch
                            I actually put a couple passes. Didn't remember,"" multi-tasking a lot these days""
                            And some cylinder guards
                              Thanks for the clarification
                              CutSkill O/A setup
                              Speedglas 9100xx
