Royal 44-30 Premium Nickel-Iron-Manganese Mig Wire for cast iron.
  • Royal 44-30 Premium Nickel-Iron-Manganese Mig Wire for cast iron.
    I just bought 2# spool of .035 Crown Alloys Royal 44-30 Premium Nickel-Iron-Manganese Mig Wire (ER NiFeMn-CI) to use with my Mig on some small castings that need built up. Figured i would give it a shot and take some before and after pics. The 2# spool was 75 bucks so it will be an expensive test but i have wanted to try cast and mig for 35 years. You can use CO2, Argon, or 75/25 gas and i have all 3 to try. I have some lathe parts to do then they wil be ground back to shape after filling the marks with weld. Pics tomorrow...Bob
  • Spotted Horse
    I'm sure the plastic spindle will come off, there is tensioning nut.
    I really like your adapter, gets the spool more in line with the guide tube, and drive rolls! Digging around a little I see Lincoln even sells an adapter for the 8-inch spools. Doesn't look like it has as much extension as yours though.
    Thanks so much for the fast response.
    http://www.lincolnelectric.com/en-us...x?product=K468
  • aametalmaster
    Originally posted by Spotted Horse View Post
    I hate to bring up such an old thread.
    With this wire coming in a 2 pound spool, how big is the center hole of the spool? Well these spools fit a normal 2 inch spindle?
    Thanks in advance!
    It is a 5/8" hole. Can you take the plastic spindle off and there is a 5/8" bolt under it? I made an adaptor for my small spools....Bob
  • Spotted Horse
    Thanks in advance!
  • aametalmaster
    Originally posted by jbmprods View Post
    i'm interested in hearing your feedback as all i ever use is stick to weld cast....jim
    Thats all i have used for the last 35 years is stick. My fav rod is Crown Alloys 255 but i have been dying to try mig for the last 30 years just didn't have the wire...Bob
  • jbmprods
    novel idea Bob... precooled cast or high gas bill for preheating. you got the snow but we got the water. i thought i was going to have fire up the boat to get to the shop. found out rubber boots and welding don't go hand in hand. i'm interested in hearing your feedback as all i ever use is stick to weld cast....jim
  • aametalmaster
    Thats great to know on the wire. My welding table has 4" of snow on it so it may be another day or two...Bob
  • Awestech
    I've been using that wire for many years to repair cracked engine blocks, cylinder heads, manifolds, etc. and it works great.
    I've only had trouble MIG welding cast iron once. I was trying to weld up a crack on a very old exaust manifold and no matter what I did I couldn't get the weld to stick. I think that the manifold around the crack was too contaminated with exhaust by-products to let the weld stick.
    But other than that manifold, I have successfully welded many many cast iron things using that wire.
